02-27-2024 12:03 PM - last edited on 02-27-2024 05:27 PM by Kristoff
So i apprecite the help I recd regarding my previous question regarding the 1x4 extender it was a great help. so heres the new challenge. Only in the M mode I am getting a shadow in the lower left corner. This happens only in the manual mode and not in any other mode. Any ideas??
camera is 90 D with zoom lens EF 100-400 L IS II
02-28-2024 09:45 AM
in the P mode 1/125 F4.0 ISO 160
same in the m mode and neither showed a shadow
what should that tell me?
02-27-2024 07:24 PM
@Dmcd3055 wrote:i do not see it in the view finder or the live view
But you get it in M mode and not P mode, even with the same camera settings?
02-28-2024 09:45 AM
02-28-2024 09:50 AM
If it was just one shoot I wouldn't worry about it then (since you can't seem to reproduce it).
02-28-2024 10:00 AM
I do not have EOS 90D, so this is a guess. You might have "Auto Lighting Optimizer" enabled in the camera menus and "Auto Lighting Optimizer" might be disabled in manual mode. It might not be possible to disable "Auto Lighting Optimizer" in auto mode.
https://support.usa.canon.com/kb/index?page=content&id=ART175434
: Auto Lighting Optimizer ] is set to any setting other than [Disable], the image may still look bright even if a decreased exposure compensation for a darker image is set.
From EOS 80D manual:
