02-27-2024 05:33 AM - last edited on 02-27-2024 12:02 PM by Kristoff
I am sure this must have been discussed before.
I have had my Mk3 from new around 2009 and it has not had much use and is still in mint unmarked condition.
However after about 3 shots the mirror stays up and i have to switch it off for it to go back down and then switch on again to use, until it stays up again.
I have used it like this for years but no I want to fix it so does anyone know what I need to do to correct it!
its 559799
02-27-2024 07:35 AM
The 1D Mark III has reached the end of the Canon repair period, so I don't know if you will be able to get this resolved.
Products that have reached the end of the repair period | (canon.jp)
02-27-2024 11:00 AM - edited 02-27-2024 11:01 AM
"... I don't know if you will be able to get this resolved."
At Canon he means. There are other repair shops that can service it. But first you have done a complete reset? Complete??? There is a date/time battery (CR2025) which maintains the camera's date and time and settings. Its service life is about 5 years so replace it. Also a new main battery Canon brand if possible.
If it still misbehaves then it truly needs service. The problem is parts not finding a repair shop. Parts will be difficult.
Try Camera Repair Center Inc.
02-27-2024 11:04 AM
Again I can't stress enough the complete reset and new batteries. That's why I am posting this again. You have to do this first. When you replace the button battery take your time doing it. Even let the camera sit for a few minutes to completely drain it.
02-27-2024 11:31 AM
Im embarrased to say that I dont know where the button battery is? can you kindly tell me?
02-27-2024 11:32 AM
and its Err 99!
02-27-2024 12:00 PM
found it - the cr2025 is out now for the first time since it went in at the factory!
02-27-2024 04:53 PM
Do you have the manual for the camera? Page 188 shows where the clock battery is.
If you don't, download it from https://www.usa.canon.com/support/p/eos-1d-mark-iii
You can also find on eBay printed manuals, both the factory-supplied book and printed 7 bound 8.5x11 copies.
02-28-2024 03:55 AM
I found it and replaced it with a new duracell 2025, I waited an hour between taking the original battery out and putting the new one in.
I did manage 30 photos before error the first time and then only 3 photos on the second attempt - so no improvement.
I have ordered a new main battery to see if that helps.
02-28-2024 05:31 AM
Update - changing the CR2025 did nothing - so the 15 year old cr20205 was still ok!
When my main battery is charged up 3 green lights on the charger and I press calibrate - it drops to 2 green lights! so maybe my main battery is the problem ( i have ordered a new main battery already) just waiting for delivery.
