02-27-2024 12:03 PM - last edited on 02-27-2024 05:27 PM by Kristoff
So i apprecite the help I recd regarding my previous question regarding the 1x4 extender it was a great help. so heres the new challenge. Only in the M mode I am getting a shadow in the lower left corner. This happens only in the manual mode and not in any other mode. Any ideas??
camera is 90 D with zoom lens EF 100-400 L IS II
02-28-2024 09:45 AM
in the P mode 1/125 F4.0 ISO 160
same in the m mode and neither showed a shadow
what should that tell me?
02-27-2024 12:05 PM - edited 02-27-2024 12:06 PM
It's helpful to have a full idea of what's happening.
What camera are you using? What lens?
Can you provide a photo illustrating the issue?
02-27-2024 01:09 PM
Vingnetting perhaps? Is the extender and lens all aligned well? Do you perhaps have a lens hood that isn't completely circular such that it's leading to vingnetting only in one corner? Or, is it really the case where vingnetting exists in all four corners and the images you're looking at make it difficult to see the effect in some corners?
02-27-2024 05:06 PM
happens even with the extender removed
02-27-2024 05:23 PM
Do you have any other lenses you can try? Very odd that this only happens in Manual Mode. If say you switch to Av mode, take a shot (and make a note of all the settings that were used), switch to Manual and adjust to those same exact settings as used for the Av shot, this still happens?
Have you tried resetting the camera back to factory defaults?
02-27-2024 05:25 PM
Can you test with another lens?
If you are seeing this effect with no hood or extender, it might be the shutter if it follows with any lens attached.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
02-27-2024 05:38 PM
with all lenses
02-27-2024 05:53 PM
Since all lenses, sounds like you need to contact Canon and see about having your camera repaired. Though do first try resetting the camera just in case that clears up the issue (doubtful though).
02-27-2024 07:08 PM
Do you see it in the optical viewfinder? Do you see it in Live View?
Set the camera to P mode and record ISO, shutter speed and aperture. Then set the same settings in M mode.
02-27-2024 07:23 PM
i do not see it in the view finder or the live view
