06-11-2013 01:55 PM - edited 06-12-2013 01:29 PM
The video shutdown usually occurs 4-6 seconds into shooting. It may happen 2-4 times in a row and then the next time it shoots perfect video. I recently returned from a cruise to Alaska. Why on a day cruise, taking pictures of whales, I talked to two other T3i Rebel users and they have the same problem. I don't use the video mode very often, but when I do, I expect it to work as well as the rest of the features in my T3i. I am very surprised that I cannot find other Canon users, in this forum, that have experienced the same problem.
06-13-2013 01:52 PM - edited 06-13-2013 01:53 PM
Just read up on the "Extreme Pro" SanDisk 32GB ........... certainly worth a try, as I would like to shoot more trouble free HD video
06-11-2013 03:31 PM
06-11-2013 04:09 PM
Good luck. We have checked and there a no updates for my camera. The camera was updated in March. Canon denies that there is a problem. Thanks for the response.
06-11-2013 04:49 PM
I have the exact same problem. The camera stops recording video recording if I move the camera around but if I hold the camera steady or mount it on a tripod I dont see the issue.
06-13-2013 05:11 AM
I had the same problem. It is not your camera. It is your SD card. The card can't store all of the information quick enough so it stops the video.Try upgrading to the extreme pro SD card. Its expensive but since changing, I've had no issues in the last 2 years.
06-13-2013 01:48 PM
I am using a 32GB Scandisk Ultra "10".
06-13-2013 02:15 PM
Just purchased a Scan disk Extreme Pro for 59.95.
07-08-2013 11:01 AM
Hello, I was wondering if the Pro card fixed this problem for you? I have a T3i and a Sandisk 32 GB class 10 card. Video usually shuts down after ~3 seconds a few times, then it will stay on for a longer video after 1-3 tries. I see the buffer meter on the side and it goes up to 2 dots then the video turns off.
This seems to happen regardless of how full the card is, how long the camera has been on, or environment (usually indoors). I format the card everytime I empty it.
I really don't want to buy yet ANOTHER card, but if it is fixing the problem, I might. I'm frustrated with missing video moments with my toddler due to this happening. I've read a lot of this issue happening on other forums with little consensus on why it really happens.
07-08-2013 11:17 AM
I purchased the Extreme Pro sandisk and have not had a problem since ( going on 3 years). It is expensive but worth it. The other disks cant be written to fast enough... thus the meter and shut off.
