06-11-2013 01:55 PM - edited 06-12-2013 01:29 PM
The video shutdown usually occurs 4-6 seconds into shooting. It may happen 2-4 times in a row and then the next time it shoots perfect video. I recently returned from a cruise to Alaska. Why on a day cruise, taking pictures of whales, I talked to two other T3i Rebel users and they have the same problem. I don't use the video mode very often, but when I do, I expect it to work as well as the rest of the features in my T3i. I am very surprised that I cannot find other Canon users, in this forum, that have experienced the same problem.
07-08-2013 12:15 PM
TTLM, I'm glad you mentioned it because I solved the problem the same way you did. I bought the higher-end Sandisk card and now I'm golden.
So yeah, it isn't the camera. It was the disk.
07-08-2013 12:57 PM
It was the SD card and A Extreme PRO SD card resolved the problem. Thanks to TTLM for heads-up
07-08-2013 01:05 PM
Thanks for the quick responses!
02-02-2015 08:14 PM
Have you tried going to the MENU button and seeing what your auto shut down setting is at? Mine was at 15 seconds! But it had time options including "turn off" auto shut down.
02-15-2015 05:15 PM
Actually, I tried a faster card and the problem hasn't reoccured. Thanks!
02-20-2015 11:58 AM
Mine was doing the same thing. I had a (SanDisk Ultra 32GB class 10 30MB/s) Memory card. You can go to your (menu) and turn down your (Movie Rec. Size) 640x480 30fps. Or you can buy a memory card that reads faster (Sandisk Extreme Pro 32GB class 10 95MB/s) The number 95MB/s is how fast the memory card can read. You can go look at charts that tell you about how many MB/s your camera needs to record without shuting down. Mine had to be over 80MB/s so I bought one that had 95MB/s.
