09-25-2016 02:28 PM
Just getting used to my Rebel T5 and I must have pushed a button and now every pic is blurry. Any help would be appreciated.
09-25-2016 03:18 PM
@AngRae2 wrote:Just getting used to my Rebel T5 and I must have pushed a button and now every pic is blurry. Any help would be appreciated.
Make the the MF/AF switch on the lens is set to AF.
Then take a picture of something outdoors in the sunlight with the camera in 'Green Square' mode.
09-25-2016 11:38 PM
PLEASE learn the exposure triangle. There are many 3 minute vids on YouTube, etc. Watch 4 of them and your answer will be clear.
09-26-2016 01:17 AM
This is the correct answer.
"Make the the MF/AF switch on the lens is set to AF.
Then take a picture of something outdoors in the sunlight with the camera in 'Green Square' mode."
Do this before learning anything additional. If it works doing this test, there is nothing wrong with the T5. Make sure the subject is around 20 to 25 feet from you.
If it does work and I suspect it will, you do need to learn more about your T5.
09-26-2016 09:59 AM
Just yesterday I was taking some RAW test shots with my T6S. I stumbled upon a preying mantis and took a few shots of it. When I got inside I saw that my DOF was pretty shallow and I had focused on his back, not his "face". Just a snap, so no big deal, but something I should have chimped on the LCD.
