04-15-2015 11:48 AM
04-15-2015 11:54 AM - edited 04-15-2015 11:55 AM
On/off-button is a is just a software power off button. Remove the battery.
What kind of camera and what version of firmware do you have?
04-15-2015 12:01 PM - edited 04-15-2015 12:01 PM
Did you happen to set the camera to bulb? You may just have to press the shutter button a second time.
04-15-2015 12:04 PM - edited 04-15-2015 12:12 PM
@TTMartin wrote:Did you happen to set the camera to bulb? You may just have to press the shutter button a second time.
Possible if she has taken a bulb picture for about one hour in duration and used noise reduction for long exposure.
Just pressing bulb once without keeping it pressed will just take a picture.
04-15-2015 12:11 PM
04-15-2015 12:24 PM
04-15-2015 10:57 PM
My mistake. Other cameras I've owned had one press to open the shutter during a bulb exposure then a second press to close.
However, accidentally turning on mirror lockup can mimic the same thing. First press locks up the mirror, which can be confused with taking a picture.
04-16-2015 09:27 AM
All of that is not what is wrong! Sorry. One 'cheap' possibility is the SD card is corrupted. The other more expensive one is it has failed and will need repair.
