03-26-2018 09:25 PM
hello everyone ! not sure where to post this but I do hope I'm on the right section. oh and sorry for my poor English.
anyway i just recently bought a canon M100. I don't know what is up but every time my stored photo on the sd card reaches 100 it creates another folder. I've checked the settings/menu and I've set the "create folder" is on Monthly. can anyone help me out ?
here is the screenshot
03-27-2018 08:25 AM - edited 03-27-2018 08:26 AM
Do you have the user manual ?
http://gdlp01.c-wss.com/gds/0/0300027770/01/eosm100-um-en.pdf
You have choice to set the folder and file numbering method.
03-27-2018 08:47 AM
hi lly3988! yes that is the current setting of my camera now.
03-27-2018 10:46 AM
Do you remove the SD card and reuse it without deleting the old folders? If you do the camera will make a new folder each time. Folders should start over at 9999 shots. Also if the folder number reaches 999 the camera will not shoot at all.
03-27-2018 07:12 PM - edited 03-27-2018 10:18 PM
oh i dont remove the sd card and i barely delete the files in it and folder. the only time i delete files if if the sd card is already full.
my old camera canon G15 doesnt do this and yeah i think it was around 1000 pictures before it creates another folder.
edit
i tried using a new sd card and same result.
03-28-2018 06:31 AM
@zyclonenuzoh i dont remove the sd card and i barely delete the files in it and folder. the only time i delete files if if the sd card is already full.
This is not a good practice. Much better to download the files after each session and reformat the card before using the camera again. Deleting the files in-camera has caused problems for some people.
03-28-2018 07:51 AM
oh ok. thanks for the tip.
03-28-2018 10:09 AM
"Much better to download the files after each session and reformat the card ..."
This not just good advice, it is great advice. I think the practice of storing pics comes from people that use their cameras like they use their smartphones. But it does depend on how you intend to use your camera.
03-28-2018 04:26 PM
@ebiggs1wrote:"Much better to download the files after each session and reformat the card ..."
Erasing not enough? Do the actual FORMAT each time?
03-28-2018 08:25 PM
@ebiggs1wrote:Do you remove the SD card and reuse it without deleting the old folders? If you do the camera will make a new folder each time. ...
Only if the reuse is on a different camera.
