04-01-2022 01:18 AM
I bought an eos m50 mark ii and I'm using it with the tamron 16-300 that I used with tho old 70d succesfully.
in some pictures I receive green and violete lines, in my country recommend me to use only canon lens (?), I don't think that this is the problem. somebody can help me?
thank you
Mauro
04-01-2022 05:05 AM
First, it's hard to gauge the issue without some sample images along with their EXIF data to evaluate. If you have similar images from the 70D to compare with, that might be helpful. You are assumedly using the Tamron lens on the M50 MkII via an adapter. Is that a Canon adapter or a third party unit?
04-01-2022 06:08 AM
04-01-2022 06:09 AM
thank you, the adaptor is canon, the same picture with the 70d is perfect
04-01-2022 07:00 AM
I own an M3. I quickly realized that most EF/EF-S mounts lenses are just too large tor the tiny M Series bodies. The only Canon lenses I use with it are the Canon “pancake” lenses. Larger lenses tend to draw too much power, and strain the mount adapter.
All Canon lenses work, but I cannot speak for third party lenes. If you wish to continue using the Tamron lens, then I recommend a DSLR or the RP.
04-01-2022 08:25 AM
That is chromatic aberration, a lens defect. The camera can correct this with Canon lenses.
04-01-2022 10:18 AM
thank you, the lens works perfectly with the 70d body
04-01-2022 11:06 AM
It could be due to the adapter, or the 70D might be able to correct it.
04-02-2022 12:39 AM
thanks
04-08-2022 08:41 AM
