04-07-2022
10:22 AM
11:30 AM
I shoot local bands and my pictures are coming out really dark even with the stage lighting I also am requesting suggestions for speed so that when band members are in motion the pictures don't blur I own a Canon T Rebel 6 ...Help Please
04-07-2022 11:20 AM
What lenses do you have? What settings do you use?
04-07-2022 11:58 AM
In general, there are four things that can be done when in low-light situations:
Though the first two in your case I believe would be not be an option (flash/lighting not allowed at the venue, and your subjects are moving).
So it would be a balance of the latter two. If your lens has a maximum aperture of say f/3.5 or even f/4, that's going to be tricky and you'll need to increase ISO quite a bit, leading to noise. You may find that you'll need to invest in a faster lens (at least f/2.8, but a 35mm f/1.4 say would really help).
04-07-2022 07:51 PM
I have a macro 0.25/8ft ..settings read 1/80 F4.5 I'm ISO 3200 not sure what to expect the White balance at for light I need more light for sure.
04-07-2022 09:44 PM
No, what is the name of the lens, we need the focal length and the maximum aperture like:
EF 100mm F/2.8
