08-16-2016 05:29 AM
hello all;
I have a problem with the touch screen, yesterday I turned on the machine and the screen does not work anymore, the screen lights up but is still black. The touch works because after pressing the menu button and tapping the screen i hear the beep sounds.
Otherwise the machine works perfectly, I can take pictures and use it via pc.
I hope it is only the screen broken, but it is strange that the touch and light work.
the machine has more than two years and never had any problems, the last time used two weeks ago and then stored without battery.
has anyone had similar problems, there something I can do?
09-07-2016 04:15 PM
I am having the EXACT same problem ! I have googled everything and can't figure it out 😞 Have you figured out how to fix it?!
09-07-2016 05:35 PM
Just a wild shot in the dark...have you checked the LCD brightness setting? It might inadvertently get changed to minimum brightness?
09-09-2016 05:43 PM
I have not solved the problem, tried to change the screen but does not work, is not the screen the problem.
I use the machine only at home and for the moment use it with an external HDMI display.
I think the only solution is to send the machine to canon for repair.
09-09-2016 06:31 PM - edited 09-09-2016 06:31 PM
@Bronco wrote:I have not solved the problem, tried to change the screen but does not work, is not the screen the problem.
Plugging a connector, or cable, into the HDMI port will cause the LCD screen to blank, in much the same way plugging a pair of headphones into an old-fashioned, compact stereo would mute the speakers.
The camera has only one chipset to produce a video output signal. Normally, that signal is routed to the LCD screen. However, when you plug into the HDMI port, the video gets re-routed to the port, which blanks the screen.
09-10-2016 04:34 AM
yes, what I meant is that in order to change camera settings i use an external monitor.
The camera screen not work in every case, tried to change all the settings, connect/disconnect to pc or hdmi but nothing.
Tried to replace the LCD with a compatible spare part but same problem, the LCD lights up but remains black.
