10-01-2021 07:19 AM
I'm not able to connect my EOS R to my iPhone 12 Pro Max using a USB cable. I didn't have this problem with my 70D, which connected immediately.
10-01-2021 12:13 PM
Is everything else the same? Same phone and version of iOS?
10-02-2021 10:21 AM
You were able to connect the 70D to an iPhone 12?
What app were you using? I believe the Canon Connect app is strictly wireless. You would connect via Wi-Fi or Bluetooth. The app does not work on USB, AFAIK. I recommend using Bluetooth.
10-09-2021 12:09 PM
identical
10-09-2021 12:11 PM - edited 10-09-2021 12:15 PM
I'm not using an app.It's a direct physical connection between the camera and the iphone using a usb/lightening cable. the connection should be automatic, just like it is with the 70D.
10-09-2021 12:33 PM
08-06-2023 09:23 AM
Upgrading a cable or even a lightening cable adapter to use USB-C should be simple enough. I don’t know why cable manufacturers haven’t done it yet since Canon is now using using USB-C connectors exclusively.
08-06-2023 10:48 AM
Thread is nearly 2 yrs old 😉
