camera does not add shutter count number on photos
Markmaged
Camera-Shutter-Count.pngCamera-Shutter-Count.pngcanon D1300
camera does not add shutter count number on images
3 REPLIES 3
jrhoffman75
Correct. ShutterCount by Dire Studios is a reliable program. macOS only. Most consider the value of having the info is minimal.
Peter
Only a few older cameras from Canon show shutter count in Exif. For example 1Ds II. For 1300D, use a dedicated software like jrhoffman75 already mentioned.
Tronhard
VIP
VIP
If you leave the settings for file numbering at their default: i.e. continuous numbering and not resetting with a new card, and do not manually reset the numbering, or low-level format your card, then the number in the file name in the form ###-#### should be the shutter count.  That usually starts at 100-0001 and will go to 100-9999 then start at 101-0001 again (i.e. a counter reset every 10k).
cheers, TREVOR
