04-01-2022 02:49 PM
Hi There ;
Anyone having trouble with setting up 5Dm4 Wifi with MAC Monterey ?
04-02-2022 08:41 AM
Hi billboman99,
Thanks for checking in with us.
If you haven't done so already, I recommend that you update EOS Utility to version 3.15, which we updated to be compatible with Monterey.Then try doing the Wi-Fi setup again.
You can download the software from our website. Let's start by going to www.canoneos.com.
On the new page that loads, click on DRIVERS & DOWNLOADS link on the top right. Enter your camera model in the prompt, select it from the options that load under the box, and then press ENTER on your keyboard.
Then you should see the link for it.
The file you'll download is actually a zipped file. When it finishes downloading, you'll want to double click the file. This will create another file with a drive icon in the same location. Double click that and you should see the installer screen. Follow the onscreen instructions, and the programs you need should then install.
04-06-2022 07:13 AM - edited 04-07-2022 01:05 AM
@HP Instant Ink Phone Number wrote:Hi There ;
Press the Menu button.
Tap on the wrench and then sub menu 4.
Tap on Communication Settings.
Tap on Built-In Wireless Settings.
Select the function you'd like to perform with the connection.
Enter your network password, then push the Menu button.
Select Auto Setting > OK.
04-13-2022 03:22 PM
Thanks very much for the info. Worked like a charm. The only thing is that I have time to knit a sweater in the time it takes to download pictures. Tether cable is 100 times faster
05-30-2025 12:49 AM
Yes, some users have reported issues connecting the Canon 5D Mark IV Wi-Fi to Macs running macOS Monterey. Here are a few tips to help:
If it still doesn’t work, a full reset of the camera’s network settings and a fresh Wi-Fi setup often helps.
