07-19-2025 08:35 PM
07-20-2025 09:09 PM
Is the camera set to C-RAW by any chance? If so the megapixels will be lower.
07-19-2025 08:40 PM
What lens are you using if you're using an adapted EF-S lens or RF-S lens the camera is put into crop mode. Limiting how many megapixels you'll have. Since the entire image sensor is not covered by the lens' image circle.
07-20-2025 08:42 PM
Thanks Demetrius. I use RF lenses, so that's not it. I appreciate it, though.
07-20-2025 08:46 PM - edited 07-20-2025 08:47 PM
@LizinJax wrote:
Thanks Demetrius. I use RF lenses, so that's not it. I appreciate it, though. Check the aspect ratio.
Make sure the camera is not in crop mode.
07-20-2025 08:50 PM
Can you show us a picture of how you're determining what megapixels the camera is outputting. Or are you mistaking megabytes. Can you please please provide the EXACT model name of the lens. Saying "RF 24-105mm" is NOT a COMPLETE name. Canon has made multiple lenses with that name so an exact name is needed. A complete name would be RF 24-105mm F/2.8L IS USM Z lens.
07-20-2025 08:52 PM
In APS-C mode it would only be 17 megapixels then instead of 24 megapixels. I'm wondering if they mean megabytes? Or do they have there RAW/ JPEG settings incorrect. But you're on to something Bill.
07-20-2025 09:00 PM
It is set to Full under aspect ratio.
Keep thinking though. I need and appreciate your help.
07-20-2025 09:09 PM
07-20-2025 09:12 PM
The file sizes are not consistent. Some are 24 meg, some are lower, llke this set I took on Friday. 7/18
The lens used here was the 24-105 that came with the R5 in a kit.
07-20-2025 09:17 PM
Are you sure you're not confusing megabytes and megapixels those are NOT the same thing. Every file can be different sizes they won't always be the same. In your picture "KB" mean Kilobytes which has nothing to do with megapixels. Now "MB" means Megabytes and NOT megapixels.
