11-23-2014 11:54 PM
I have a Rebel T3i and am interested in buying a new lens. I have a two year old and need a camera that is going to be able to capture action with no problem. What lens do you suggest for greates action but for a resonable price? I currently have the 18-55mm and the 75-300mm.
11-24-2014 06:21 AM
11-24-2014 09:47 AM
"What lens do you suggest for greates action but for a resonable price?"
What is this, "reasonable price"? What you have covers a great deal of photographic situations. Except, low light, indoor shots. So, obiviously, you need a faster lens. And faster lenses are not usually cheap.
Your current lenses quickly fall into the f5.6 range so getting a faster lens is not too difficult. Any lens with a constant f2.8 will help you.
The suggestion of a 50mm f1.8 or better the f1.4 version satisfies the low light and "reasonable price" but they can be more difficult to use on a "moving" 2 year old inside.
The EFS 17-55mm f2.8 will be an improvement over your current lens but only a little. It remains f2.8 through out a big plus.
Both Tamron and Sigma make a similar lens in this range and may be slightly cheaper.
Have you considered a 430EX II flash? It is light years better than the dinky pop-up flash on the T3i.
11-24-2014 02:43 PM
@ebiggs1 wrote:"What lens do you suggest for greates action but for a resonable price?"
With the 17-55 f/2.8 you have to have external flash. The lens is so big that it casts a significant shadow in the light from the onboard flash. I learned that the hard way. (I learned it on a 7D, BTW. On the smaller Rebel it figures to be even worse.)
