What happened to my fireworks photos?
ruby3
Fireworks started out Bulb, manual focus, F8, tripod, remote shutter, 2 to 10 sec timed exposure
18 REPLIES 18
ruby3,
Yes, it looks like maybe you might have been confused about the 2 second and 10 second timer.
Those are just a timer that waits 2 seconds or 10 seconds before the shutter snaps.
You need to set a shutter speed yourself. A shutter speed of anywhere from 2 seconds to 5 or 6 seconds should be pretty good for fireworks, I would think.
Steve Thomas
I am using a remote shutter release and I just do different counts, sometimes to get several bursts in a frame.  I got some good shots in 2024 but looking at the information on the shots that year and this year last year I use a f16 and this year a f4 to a f8 and other than that I had the same settings as the year before.   These was last years.  Although I still think even these settings need to be better.last years at f16last years at f16last years with a f16last years with a f16
I was using 100 and a remote shutter with bulb that I liked to keep open for several burst, not a camera timed setting.  I would use different counts but usually a count to 10 and release.
tamron 18-400mm manual focus
with vc off EOS 90D  remote release and I count to 10 or there abouts  I think maybe my fstop was wrong, because I looked at the info on the pictures last year and I was using a f16 instead of a f8
see early reply on what I got last year with a f16, remote shutter release  I would count out to 10 cause I wanted multiple bursts in a frame.   i think it was my f stop cause it was the only thing different than last years but all the sites was saying f8 and i know I failed in some because it was in f4
I was using a Canon D90 with a tamron 18-400 lense, manual focus, bulb setting with a remote shutter release, 100 ISO and counting to 10. I compared this year to last years and I see that the only difference was the fstop.  this year it was f4, totally bad, f8 better, but nothing compared to the f16 that I got last year,  But not totally happy with the f16 either.  I posted to a earlier reply a couple of the ones from last year.  I also diaabled the VC on the lense and focused the shot manually to where they was going to go off, which was inf.  But it wasn't a focus problem..I know it was the fstop but trying now to figure out what the ideal fstop is.
time on that one and the fstop diffinitely.  I usually do a manual count slow to 10.   On earlier replay I posted what I had done the year before.  I am seeing a problem with not KEEPING MY COUNT ON SECONDS CORRECT ON MANY AND THE F STOP
I was looking at last years and the f stop and my timing was bad this year.  I had better luck at a higher f stop and a longer count.  I was trying I think to just capture one burst and than close the shutter and that was not enough time at that lower f stop.  I posted some from last year way better  longer shutter time and at a f/16.  I did get some shots this year atIMG_3556 copy.jpg f/8 but with longer shutter time.  this one was at F/5.6 ISO200, 7.6 sec.  I just got to find the right formula.  But you are right the time the shutter was open was way too little on that one.
ruby3,
I have read a tip from a guy who took 30 second exposures, and held a black card in front of his lens. Every time a firework went off, he would take the card away for about 5 seconds, and then replace it. That way, he was able to fit several exposures into the same shot.
I've never tried that myself, but the concept sounded intriguing.
Steve Thomas
ruby3
exposure time is way off.  I can see.  I change settings a couple of times in shooting and had better luck at some of them, but I want to try to find a consistent success.  definitely my shutter time was way wrong but was getting some shots at f/5.6 but at a shutter of 19,..I was using a remote battery powered shutter that worked the night before and then the  second night until I switched over to the hand held shutter release was doing 1/40 second continueously.  So maybe the battery on it needed to be changed or something that it wasn't doing what it was suppose to do.  I probably just to be on the safe side should have put fresh batteries in it.  But it seemed to be working but each shutter speed on the bad shots are all the same so it wasn't operating correctly.
