01-10-2021 02:25 PM
On Canon's list of supported beta webcam conversions: Canon U.S.A., Inc. | EOS Webcam Utility, they list some camera's as "** USB not included with camera". What does this mean? For example, the Rebel T8i has a "**" and yet on BestBuy specs it says, "Outputs: 3.5mm audio, HDMI, USB". I want to be able to hook this up to a PC and use for webcam. That's my goal. Which camera under $1000 is my best choice?
01-10-2021 03:27 PM
I believe it means a cable is not supplied.
01-10-2021 08:03 PM
Yep. That was it. Now that I have it, and I'm using their beta software, I'm not really satisfied with the video quality. It stutters a little - not sure if "slow frame rate" is the right term. As I move and speak, it looks just a little jerky. And the video lags the audio by a hair (using a Yeti mic and not the onboard camera mic). So... a little more tweaking before I give up.
01-10-2021 03:27 PM
01-10-2021 08:03 PM
01-11-2021 09:41 AM - edited 01-11-2021 09:41 AM
@Mercusio,
What are the specs of the PC you are connecting to?
Type of storage? (plattered disk, SSD, m.2)
CPU?
Amount of installed RAM?
Does it have a dedicated GPU?
01-11-2021 09:39 PM
My Rebel T6 Camera is connected via USB into WIndows 10 64 bit Dell. The camera is in the video mode/ and I can see the image on LCD just fine. However, my problem is the computer never detects Canon Rebel. I can plug a Cheap camera into the same USB port. and it is detected immediately. In a few minutes, Rebel T6 clicks off.
01-11-2021 10:32 PM
I use a Microsoft Surface Pro, i7 2.5 GHz, 16 GB RAM SSD plenty of speed and space. I'm going through USB 3.0 with the connector from the camera.
I got a partial answer from another poster that said that Canon slowed down the frame rate on the webcam software to avoid sensor overheating. It seems to be a trade-off... do you want no perceptable flicker but flat colors by using a webcam like a Logitech Brio? Or do you want warm studio colors but put up with a slightly perceptable stutter of a reduced frame rate? I'd like both in one solution. I may take this camera back and try something else. Not sure yet.
01-11-2021 10:34 PM
Have you downloaded the beta webcam drivers for your T6? Canon U.S.A., Inc. | EOS Webcam Utility
01-11-2021 10:50 PM
Not yet. Many thanks. I will give that a try.
