Viewfinder trouble on 70D
Twinmum
Hi, I've had my camera (70D) for a few years now  and this morning it started doing something it has never done before.  When I turn the camera on I can't see through the viewfinder (yes lens cap is off) It happens in all modes, however, while it is on, if I turn the dial to change modes a couple of times, it clicks and then I can see through the viewfinder. I can then move the dial back to the setting I want and can see through the viewfinder still. However, as soon as the camera is turned off and then back on, the problem returns.
I saw a similar problem here about seeing through the viewfinder and so followed the suggestion of removing the lens and dusting out the cavity while holding the camera facing down. I've checked and the lens is attached properly. Neither of these fixed the problem.
Any suggestions as to what might be going on?
thanks
Waddizzle
You could have Live View enabled, or Movie mode enalbed.  I don't think so, though.  Check for Mirror Lockup mode being enabled.
2 REPLIES 2
Waddizzle
OK, now I feel foolish... just checked and it was in live mode. Flipped the switch and now it's back to normal. Thank you Waddizzle
