01-16-2024 03:25 PM
Anyone used a T7 for videos? The manual says it takes a certain memory card. Just asking as I might try it.
01-16-2024 03:42 PM - edited 01-16-2024 03:43 PM
John,
The manual says your camera will take SD, SDHC and SDXC cards.
It's actually compatible with the newer UHC -1 cards, but you won't get any real benefit from those, because the cards are faster than the camera's processing speeds.
You might want to look at this web page. Do a Google search for this exact phrase.
If you do get a new card, make sure it's at least a Class 10.
I you want to do video, my personal recommendation would be a 128g SDXC card.
Steve Thomas
01-16-2024 07:43 PM - edited 01-16-2024 07:43 PM
I would recommend against using SDXC SD cards in that camera. Those cards cause random problems such as locking up or hanging for no apparent reason. Stick with SDHC SD Cards in that camera. Even though the manual says they're compatible. They're NOT COMPATIBLE for whatever reason. They simply don't work reliably and aren't worth the headache.
01-16-2024 08:02 PM
Note that SDHC is going to be limited to 32 GB. Which for video work, can be quite limiting. Especially if the desire is to capture long-running events. If only capturing shorter segments where changing cards won't be an issue, then agreed that smaller capacity cards would be best.
01-16-2024 08:11 PM
Yes but those cameras for some reason don't work well with SDXC SD cards. They cause all sorts of problems like hanging and freezing for no apparent reason. Discontinuing the use of that particular card fixes the problem. It would be best to use a larger card. But its not worth the headache with this particular camera.
01-16-2024 08:03 PM
While a card's sustained write speed is the most important metric to look at, higher read speeds can be beneficial when transferring footage to a computer. Of course only if the computer's destination drive write speed and transport speeds (cables, ports, etc.) aren't the bottleneck.
01-16-2024 08:51 PM
I agree with Demetrius. Stick to SDHC UHS-1 Class 10 memory cards, 32GB or smaller.
AFAIK, the camera will only record Full HD for 30 minutes, and then STOP. It will come to a full stop at a 4GB file size or 30 minutes of record time, whichever comes first.
But you have had this camera body for a while. What has been your experiences with SDXC SD cards, 64 GB or larger? Does the camera ever hang or freeze up?
01-16-2024 09:02 PM
Also, the T7 is not capable of Movie Servo AF. It will not refocus and track subjects while recording video on its own. You would need a camera operator, which would be a little awkward without a joystick control.
The camera is perfectly capable of capturing “talking head” videos like you see all over YouTube. The YouTube content creator “Anton Petrov” produces videos that are a perfect example of this style of video recordings. He is a “wonderful person.”
https://youtu.be/z83lEdDgHRw?si=Dsmf7XlBbGrL7Txr
01-16-2024 09:06 PM
From Fix the photo dot com
"The 8 best SD cards for Canon T7"
7 out of the 8 are either 64 or 128g U3 Class 10 SDXC cards.
The 8th Is a 256g SDXC.
Steve Thomas
01-17-2024 04:01 AM
@stevet1 wrote:From Fix the photo dot com
Steve Thomas
I am well aware of what the camera specs say. I used to own a T5. The SDXC cards were unreliable. It seems to be an issue with just the xxxxD camera bodies.
The forum has many threads from members experiencing issues with their memory cards. Half of them are with the micro-SD cards and half are with the large capacity SDXC cards. But once they switch to a full size, SDHC card, then their problems go away.
