EOS Rebel T7 SD Card "Cannot Be Accessed" Message
lala27d
I just bought the canon t7 and i have a question  why this is coming up? I just bought a brand new sd card never used. Please help!! thank you in advance!
18 REPLIES 18
Sure, SanDisk is a good brand.    But.....128 GB is awfully large. You're better off with several smaller cards. A 32 GB card can hold tons of photos, and you should be moving files to a computer rather than trusting a huge amount of stuff to one card. Having multiple cards lets you rotate them. Fill a card, and change cards. That way if any one card dies, gets lost etc. you have not lost everything.
Tintype_18
Recording video on the T7, which I have, requires a different memory card; SD speed class 6 or higher. I would also recommend downloading the T7 manual as a PDF. I have it on my laptop and my Android phone for quick reference. There's a trainload of info there. Good luck!
John
That's why I recommend that OP get a smaller SD Card the brand is fine.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT & 600EX II-RT
-Demetrius
Bodies: EOS 40D & EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 50mm F/1.8 STM, EF 70-210mm F/4 & EF 85mm F/1.8 USM
thank you so much for this. i only got the 128 because thats the only one cvs had at the time! ill look for smaller cards for sure. i appreciate all of you and your help!
I recommend getting a few 32 GB SD Cards that should be plenty of space. I also recommend getting an SD Card reader too. This would be faster than trying to pull pictures from the camera.
-Demetrius
-Demetrius
No worries Demetrius - I know how that can work, and can be both confusing and frustrating! 🙂
cheers, TREVOR
Agree on both counts with Demetrius.  It's a good idea to take the photos, copy them onto a computer, once you confirm the files are there, put the card back into your camera and format for the next shoot.
However, a couple of things.
Removing the SD card from your camera and then uploading the files via either an SD card slot in your computer, or one attached via USB is far more reliable and faster, and takes no more steps.
If you use Windows, use the Eject command in File Manager to close open files on the card once you have completed the copy process.  It should tell you that the card is then safe to remove.
cheers, TREVOR
Waddizzle
I do not know why, but T5, T6, and T7 camera bodies and SDXC memory cards, 64GB or higher, do not get along.  I know what the User Manual says, that the cameras can use SDXC cards.  In the real world, the camera bodies frequently seem to choke on SDXC cards.
If you stick to SDHC memory cards, 32GB or less, then this current issue will go away.  Be sure to to use the camera perform a low level format of the SD card prior to first use.  They do not come reformatted.  Follow all of Trevor’s advice in the first response.
Alfred_P
I’ve run into this before, and it usually turns out to be the SD card, not the camera. This can happen if the card is starting to fail, was used in another device, or was formatted on a computer.
The first thing I’d check is the little lock switch on the card. After that, try the card in a computer or card reader to see if it’s still readable there. If there’s nothing important on it, formatting the card inside the camera often clears the error. When I had a similar issue, I used Stellar Photo Recovery, and it was able to scan the card and recover the images even though the camera could not read it.
