12-14-2016 05:56 PM
Hey all! So Ive recently started making videos on a regular basis and ive noticed a very very strong grain in my videos. Ive search basically everything up and I just cant seem to figure anything out.
This is the video I took just as an example of this horribel noise that is happening. I've tried it with higher light aswell and it just doesnt seem to fix it. If anyone has an help or suggestions that would be great!
12-15-2016 08:24 PM
These are the only options I have for IOS.... 100, 200, 400, 800, 1600, 3200, 6400
12-15-2016 09:01 PM
12-16-2016 01:31 PM
12-16-2016 02:00 PM
@Mitch345 wrote:Recording at 1920x1080 at 30 fps. I set the shutter speed to double which is 1/60. Those were just the settings that the camera came up with while in automatic.
And, what are the recording like when you use the "automatic" settings?
If you increased the shutter speed to 1/60, compared to 1/40 in the automatic setting, then you will also need to increase the ISO to maintain the same exposure, which increases noise.
BTW, the keyboard video is recorded in a fairly dark environment.
12-16-2016 08:17 PM
Yes that is very true it was quite dark. When I use manual, again, it has that super grainy look to it cause it turns the ISO way up even in decent light.
12-17-2016 04:40 PM
@Mitch345 wrote:Yes that is very true it was quite dark. When I use manual, again, it has that super grainy look to it cause it turns the ISO way up even in decent light.
Welcome to photography and videography.
You have encountered what setting an exposure is REALLY all about. You cannot have it all at once. In order to gain something, then you have to give up something. It is all about the Exposure Triangle: Shutter Speed, Aperture, and ISO.
Understanding Exposure: The Exposure Triangle
https://en.wikipedia.org/wiki/Exposure_value
