07-28-2016 08:07 PM
I have a T6i and when I connect it to an external HD monitor using the HDMI out port no image is displayed on the external monitor. the camera acts like nothing has changed.
I went into the camera settings and set the Ctrl over HDMI to Enable, but that didn't change anything.
Am I missing something?
07-28-2016 10:52 PM - edited 07-29-2016 10:20 AM
Did you press the blue playback arrow.
07-29-2016 10:31 AM
yes I have tried these steps using a few different monitors. I'm beginning to think the port on the camera is defective 😞
07-29-2016 10:40 AM
I asked if you tried a new *cable* not *monitor*, and yes, if a new cable does not work, it is probably the camera. The "control via HDMI" has nothing to do with this. That simply allows you to control the camera with the TV remote - which I have never had success with, though my T6S displays on my HDMI TV's just fine.
Have you tried the composite video output?
07-29-2016 10:47 AM
07-29-2016 10:58 AM
It does have composite out with Canon cable. Plugs into USB port.
07-29-2016 10:59 AM
07-29-2016 11:04 AM
@mderksen wrote:
Sorry my response was to the first person who responded. and I also tried multiple cables as well.
I don't believe my camera has a composite video out option. the HDMI is the only one I can see, unless I'm missing something which is possible.
Is your LCD still active when you plug in the HDMI cable? It shouldn't be.
07-29-2016 09:48 AM
I would try a different cable.
11-29-2016 01:17 AM
