SL3 Power Adapter Question
Birdkage56
Hello, I have a power adapter for my SL3, and I have a question regarding power. I'm wanting to use a smart plug to power the camera on and off because the camera isn't easily reachable, but I'm not sure if that will damage the camera. Basically, what I'm asking is: is it okay to cut power to the camera suddenly?
Best regards
3 REPLIES 3
jrhoffman75
I don't know of any other way. Unplug manually or turn the camera switch - it's either on or off - so I do not think there should be any problem.
rs-eos
I think you're going to find it won't work as you'd expect.  When turning the camera off/on using it's power switch, it does more work than a typical on/off switch.  e.g. it will perform the sensor cleaning task.
So if you turn your camera on with its switch and then plug it into a switchable outlet and kill the power, you'd skip the sensor cleaning step and other power-down logic the camera would have performed.   Turning the switchable outlet back on would most likely leave the camera in a state where you'd have to physically go up to it and and interact with buttons to wake it up.
Ricky
Correct about the sensor clean, but if I have my camera awake and pull the battery it is the same effect. Putting the battery back in wakes the camera.
Since OP can’t reach camera I am guessing he would be using a remote to operate camera.
But, since it’s AC power I wouldn’t switch off.
