T5i takes photos instead of video
LilyEden
I'm not an experienced camera user.. But, one day my video quit working.  It now takes photos instead of videos when I have it set to take video.
Here are my settings in my camera:
AF method = face+tracking
Movie Servo AF Enable
AF w/ shutter button during video OFF
Grid Display OFF
Movie rec. size 1920 X1080 30 frames
sound recording On
Video snapshot Disable
I have a cheap memory card in it.
What could be the problem with it?
Thank you.
7 REPLIES 7
Please refer to your user guide.
Page 173 and ensure you have Movie Mode enabled:
https://gdlp01.c-wss.com/gds/5/0300010905/07/eos-rebelt5i-700d-im7-en.pdf
If you have confirmed the above, try resetting the camera.
What brand / model is your "cheap memory card in it?"
It needs to be:
A. Compatible with the camera and movies shooting requirements
and
B. Not a micro SD card inside an adapter.
It is in movie mode.  It's a Micro Center SDXC Extreme Speed 128 GB card.
Did you reset your settings to their defaults through your settings menu yet?
As shadowsports mentioned, try resetting the camera.
As for memory cards, never heard of Micro Center.  Personally, I only ever use SanDisk, though there are also other equally good brands too.  It's just not worth it to save some money on these other types of brands.
As of this writing, a 128 GB SanDisk at higher 170 Mbps speed (90 Mbps writes) (UHS-I / V30 / U3 / Class 10) is $35 at B&H.
Ricky
Where do you reset to default settings at?
Page 214 of your manual and also reset any custom settings too:
Switch the top dial to P mode so that you can see the full menu system.
