12-25-2020 01:30 PM
12-26-2020 01:45 PM
12-26-2020 03:41 PM
I was going to go with some RTV that I used for securing small plastic parts on my motorcycle but I opted for the GE Advanced Silicone. I will leave updates as time goes by as to how well it works.
12-26-2020 03:51 PM
Best of luck to you!
12-26-2020 06:34 PM
The silicone will probably be OK but you have to be careful with it around electrical circuits if it is of the type that outgasses acetic acid during the cure (that strong vinegar smell you get while it is curing).
Acetic acid is corrosive to copper, zinc, brass, etc. which are materials often used in various electrical connectors and switches. Once cured, it isn't a problem but what you want to avoid is a situation where the fumes from acetic acid will be trapped and contained around electrical contacts, unprotected circuit board traces, etc.
Rodger
12-28-2020 01:28 AM
@ThatJeepGuy wrote:
Hi, I have a T5i and last night the top of the mode selection wheel popped off. What adhesive would work best for reattaching this piece?
Hello from a fellow Jeepster.
Steve Thomas
12-28-2020 11:26 AM
"Hello from a fellow Jeepster.
Steve Thomas"
My son is a 'jeepster' no I mean a Jeep gonzo! ![]()
