07-27-2014 10:05 PM
Hello. I've had a T4i for over two years now. The camera has been completely unusable for more than 6 months beause it won't read any SD card I insert. I keep getting an error that says: card cannot be accessed. Reinsert/change card or format card with camera. However, I have tried multiple cards and when I attempt to reformat I get this error: Cannot format. Change Card. I'm at my wits end and really can't afford to repair the camera. Is there anything else I can do?
11-16-2022 03:38 PM
I did try one 64GB and 128GB, just to see whether they would even register. I have tried cards from 2GB to 32GB, and full size SDcards and microSD cards with adapters. Just as a stroke of luck, I had one 16GB Sandisk Ultra A1 98MB/s microSD card with adapter that I tried in the camera, and it worked. Afterward, I put that same microSD card into a different adapter (four different adapters, actually, including two other Sandisk brand adapters), and it did not work. I put it back into the original adapter, and it worked again. I put other microSD cards into the original Sandisk adapter from the 16GB card, and the other microSD cards worked. When I tried those microSD cards in other adapters, they did not work. I got a duplicate 16GB Sandisk Ultra A1 98MB/s microSD card with adapter, and that did not work. I swapped the duplicate 16GB Sandisk Ultra A1 98MB/s microSD card into the original Sandisk adapter, and then it worked with the camera.
So far, it really is only this one adapter that will work with the camera.
11-17-2022 10:11 AM
"So far, it really is only this one adapter that will work with the camera."
Perhaps that adapter wrecked something in the T4i and that why they are not recommended for use. The bottom line is micro SD cards offer nothing in benefit and are a source of problems even when they are working.
11-17-2022 10:51 AM
“So far, it really is only this one adapter that will work with the camera.”.
That pretty much sums up the issue. Doesn’t it? Micro-SD cards and adapters are problem. They are not recommended for use in Canon DSLRs.
You need to stick to using full-size SD cards with a maximum capacity of 32GB.
11-17-2022 11:04 AM
For this specific body, full size cards still won't work.
11-17-2022 11:29 AM - edited 11-17-2022 11:58 AM
maximvsv: "...and full size SDcards..."
Presuming that the full sized cards you tried were 32 MB or smaller (SDHD), the problem is apparently not simply related to the use of micro adapters.
Since you have had mechanical issues in the past (the cards not locking in place) there is a possibility that a contact, or contacts in the card socket have been mechanically damaged.
Alternately, there is an electronic problem in the camera, but that diagnosis is complicated because you are finding that you can use a Micro-SD card in the one Sandisk specific adapter. It's possible the adapter that works may have contacts that are slightly thicker than nominal for SD cards so makes contact while other "in spec" cards cannot. Externally, after all, SD cards and SD adapters are molded plastic parts and will have physical variations in mechanical specs.
The issue, and danger of using micro cards in an adapter is two-fold which is why it is not a recommended solution. First, it introduces an additional set of tiny contacts in all of the signal paths, and second, depending on how well the particular micro card fits in the particular adapter, may result in a total combination thickness that is outside of the nominal expected specification.
Using a mix of different brand micro cards in different brand adapters is risky and it's certainly possible that inserting an adapter with a tight-fitting micro card which was not full seated could damage the SD card socket's fragile contacts.
If after trying another full-sized SDHD card from a major manufacturer like SanDisk, Lexar, ProGrade or Sony, the card is still not recognized, than the camera will need to be serviced by a competent shop. Don't be surprised if they need to replace the card socket assembly.
11-17-2022 12:46 PM
@maximvsv wrote:For this specific body, full size cards still won't work.
I assume that you are saying that full size SD cards, 32GB or smaller, do not work with this camera body. If you have a card reader, try formatting one using a Windows PC. Once formatted try to see if the camera accepts it.
If the above test fails, then it is likely that your card reader port in the camera is physically compromised in some way. If one card works, then it is safe to assume that the electronics are good. Check the slot carefully under a bright light for foreign debris within the card slot.
Due to the age of this camera body, I am uncertain if it is worth repairing.
11-17-2022 01:23 PM
I formatted cards in the T4i body, on computers and in other cameras. The full size cards have ranged from 2GB-32GB. The microSD cards ranged from 8GB-32GB. The body will not format the full size cards at all, and it will only format the microSD cards if they are in that one Sandisk adapter.
11-18-2022 10:43 AM
I really doubt the internals of the T4i are damaged. If they were the micro-SD adapter would not work either. It uses the very same pins. The issue comes with the addition of unnecessary extra contacts and their associated problems.
If the micro-SD adapter is working just go ahead and use it which makes no sense.
Don't take it out. Use the USB to u/l to your computer. Otherwise repair or you may need to buy another camera.
