EOS R Spot AF
BryanShaw1
Enthusiast
One disappointing omission I find on the EOS R is Spot AF. It was present on my 7D and is there on the R5. I found it very useful when trying to pick out a wader half hidden by weeds (for example). I know there was a firmware update to add eye recognition but do you think Canon might add Spot AF in the future? Otherewise I may have to invest in an R5.
16 REPLIES 16
jrhoffman75
If it's an important feature to you the R6 Mark II will have it.
Waddizzle
That really is odd because the RP has Spot AF.
If you need an AF point that small, then it sounds like you are a little too far away to capture the shot.  Not every shot opportunity meets with success.
Independent of distance, the situation described by the OP frequently requires the small spot AF.
"trying to pick out a wader half hidden by weeds (for example)."
BryanShaw1
Enthusiast
I know what you're saying Wadd but - I had a barn owl on a post some distance away with my 100-400 but the camera focussed on the post and not the owl. Only a very small change and not noticable until reviewed on PC. Had I had Spot AF the results would have been fantastic,
Why can't you use 1-point AF and point straight at the stationary bird?
Am I missing something about your shot/subject?
@shadowsports wrote:
Exactly, my point.  Because he is too far away from the subject, IMHO.
I wish the OP would post a sample photo.  I am curious to see how large the subject is.  It sounds like the issue is with picking out a bird sitting on a distant branch, but there is not a clear, unobstructed view of the bird.
Besides, there will always be some shots you will not be able to capture for one reason or another.  Being too far away is probably the most common reason.
Let’s wait for the OP to post a photo of the issue.
Post the sample photo.  Which AF mode are you using?  Zone AF?
If a barn owl is sitting on top of a vertical post that is some distance away, then it should not have mattered if focus was locked on the post or the owl.  Both should have been captured by the DoF, anyway.
BryanShaw1
Enthusiast
So you don't believe Spot AF is a worthwhile feature? Well OK but I do, and Canon obviously does too or they wouldn't have reintroduced it on the R5 and (as John points out) on the R6 /2. Firmware update please Canon. (and I'd like to post example photos but I always delete those I don't want to keep but I'll save them in future to show you what I'm talking about). Thanks for all your comments.
