03-26-2019 05:13 PM
Hello Canon users,
I'm new there and decided to change all my gear to Canon.
I'm product and portrait photographer, shooting on location and in studio.
Because i do not have any lenses, so im looking for cheaper body and planning to buy more lenses rather than expensive body.
So i have some questions:
-Which camera autofocus will perform better EOS RP or 6d mark II ?
-Will not R line lenses like 50mm f1.2 85mm f1.4 or 24-70 f2.8 will perform good with adapter on RP ?
-Will HSS work on 6d mark II and RP when using studio lights and Cactus v6II trigger? used on 5d mari IV it worked fine..
-What abour dynamic range? Will there be DR good enough on EOS RP and 6d mark II or rather i need save money for EOS R or 5d mark IV?
-Its wise to buy EOS RP and use it for example with 70-200 ? :))
Would buy 6D mark II, it have better battery and feels in hand more comfortable, but i have feeling, that autofocus will perform much better on RP or im wrong ?
03-26-2019 05:48 PM - edited 03-26-2019 05:49 PM
It is hard to say, One difference is that you never have to worry about AFMA - that is adjusting the lens to the camera - since the RP always uses the main sensor for AF.
It appears that the adapters work pretty well.
Most of the rest is subjective.
03-26-2019 06:16 PM
Yes, but what about AFMA when not using fixed focal lenght lenses? its works fine for example when using 24-70? i mean 24mm and 70mm same AFMA required?
03-26-2019 07:09 PM
My understanding is AFMA is used to correct the difference between the focusing sensors and the actual photo sensors. In the R line it uses the photo sensors for focusing. No AFMA.
03-27-2019 02:52 AM
@Vejas wrote:Hello Canon users,
- Will not R line lenses like 50mm f1.2 85mm f1.4 or 24-70 f2.8 will perform good with adapter on RP ?
- Will HSS work on 6d mark II and RP when using studio lights and Cactus v6II trigger?
- used on 5d mari IV it worked fine..
- What abour dynamic range?
- Will there be DR good enough on EOS RP and 6d mark II
- Or, rather i need save money for EOS R or 5d mark IV?
- Its wise to buy EOS RP and use it for example with 70-200 ?
What gear are you kicking to the curb? Every brand has its’ own small edge over others. I think Canon has the best lenses, color reproduction, camera menu systems, AF tracking, and customer service. Other brands have better specs for this or that other thing, but those are less significant once you add post processing to the mix.
For product and portrait photography, here is my take on some of your questions. I own and use a 6D2, but have so far passed on the EOS R and RP. Which is better is really up to how you plan to use the camera.
There are plenty of written and video reviews of both bodies. Most seem to be biased, but there are a few that are not. I think the RP will only get the -6 Ev focusing with an f/1.2 lens.
In Live View mode, I would expect the cameras to be fairly close in performance. The RP may have more AF points, so it may look better on paper in that regard. Both cameras seem to use near identical Dual Pixel AF image sensors.
03-27-2019 09:59 AM
"I'm product and portrait photographer, shooting on location and in studio."
So you are just an amateur? Because the models you list as choices are amateur level cameras. Limited to the choices you stated I would go 6D Mk II all the way. However, if you are serious look at the 5D Mk IV. The two lenses you need are the EF 24-70mm f/2.8L II USM Lens and the EF 70-200mm f/2.8L IS III USM Lens. These are the best lenses made in the world no matter which body you buy, 6D Mk II or 5D Mk IV.
