03-10-2021 02:21 PM
Maybe I am misunderstanding the use of a speedbooster, and i am hoping someone can put me on the right path.
I have an SL3. I am being asked more and more by my company to take photos of classes we are promoting on the manufacturers website. The problem is, I find myself more and more in low light situations. Obviously, I end up getting a lot of noise in my photos, and am getting a lot of motion blur due to having a slow shutter speed.
I cannot afford a full frame camera, so the crop sensor was fine until now.
I ran across a a few articles about speed boosters. my understanding was it would take the light from your lenses, and focus them fully on the cropped sensor.
am I correct with that?
I have a pretty good set of lenses for the SL3, so my idea was to get a speed booster that fits the SL3 lenses, and be able to focus the full light onto the crop sensor of the SL3.
Am I correct? Is that how it works?
If I am, I was told Canon makes a speed booster for this.
Please help set me right.
03-10-2021 03:25 PM - edited 03-10-2021 03:51 PM
What you need is a "Light Booster".
Get a flash for your camera and bounce the light off the ceiling to light up the whole room for a group photo. If the room is too large, you may need two or even three flash units that you can fire remotely.
03-10-2021 02:38 PM
I don't think these devices are available for your camera, typically they are used with mirrorless cameras. There isn't room for these "reverse teleconverters" to mount to DSLR bodies.
Rodger
03-10-2021 03:37 PM
What lenses do you have?
If you can zoom with your feet, the Canon 50mm f/1.8 might be an inexpensive way of getting some more light.
03-10-2021 03:42 PM - edited 03-10-2021 03:47 PM
I do have the 50.
My only problem is being in an enclosed small area, and having to get as much in the shot as possible.
I have been using the 24mm. it has the perfect framing in the areas I work in.
I guess I am just waiting for the unicorn to land at my feet.
I need everything, and have nothing. LOL
Maybe I can convince the boss that the ful frame and all the lenses should go on his amex.
03-10-2021 04:56 PM
Have you tried pushing the ISO?
03-10-2021 05:43 PM
Definitely also recommend adding flash. If flash is not allowed though, are your subjects stationary? If so, use a tripod with slow shutter.
In terms of moving to full frame... A good lens will typically give you more performance. e.g. when moving from a Rebel with kit 18-135mm lens to the EOS 6D and a 50mm f/1.2L... I got at least three stops better light gathering (f/1.2 vs f/3.5 at the kit lens' shortest focal length). ISO performance I estimated around 2 stops.
03-10-2021 08:20 PM
03-10-2021 08:32 PM
03-13-2021 10:00 PM
How far have you pushed the ISO? Are you shooting in RAW or JPEG only?
Canon's DPP4 software for processing RAW files can help you deal with controlling noise issues. Also, if the images are primarily for web display only, downsizing the images for the web will make noise less noticeable as well.
