Slow Write on Canon 70D
khaslag
I recently tried to capture a set of astroimages at 15 sec. intervals over a period of 1.5 hrs (using an  intervalorometer). I should have captured nearly 560 images. But when I downloaded the images to Bridge there were only 210. Looking at the Bridge information there is an additional 18 sec between the Date Created date/time and the Modified date/time. This 18 sec. per image accounts for the difference between the expected number and the actual number. But where does it come from and how can I account for it in the Intervalorometer settings.
Canon 70D
SDXC-I 64GB SD card
ISO 1600
~25MB per image
Tried reformatting the card and that solved the problem. I'll probably purchase a new one as added insurance.  Thanks for all the help - really appreciate it.
9 REPLIES 9
jrhoffman75
Welcome to the forum khaslag.
What intervalomter were you using?
What were the camera and intervalomtere settings?
Intervalorometer was a Phottix Taimi digital timer and remote
Delay = 0
Long = 15 (sec.)
Intvl = 1 sec.
N1=1
Repeat=99
N2 not set
Also: Camera settings
ISO 1600
Exp=15 sec.
Manual Mode
Manual focus
RAW
LENR=Off
HISO Speed NR = Off
jrhoffman75
Doubke check the instructions for the intervalometer. For my three Canon cameras the camera needs to be in Bulb mode when using an intervalometer.
I took the timer out of the equation and just shot 30" in Manual Mode. The same results - it took 30 sec. to write a 30MB image to the card. I tried variations in ISO, shutter speed etc. and it appears it takes the same amount of time to write to the card as the image size (i.e. 1MB/s write speed!). Not a problem with faster shutter speeds but can be impactful for multiple long exposure astroimaging like skyscapes or meteor capture.
Do you have any in-camera processing activated?
John is correct about using Bulb mode.  What brand of card are you using?  It sounds like it could use a reformatting.
As suggested try reformatting card in camera.
If that doesn't work try a new card. The 70D should be writing much faster than you are seeing.
Friends and Family
