11-21-2012 11:40 AM
How can I determine the total number of shutter actuations for my 1Ds Mk III ? Does it really require getting some specialty software ?
01-05-2016 06:01 AM
Found today out that 1D III and 1Ds III have a shutter count tag in the image file. Thought 1D II N was the last camera with a shutter count tag in the image file.
Could somebody who owns a 1D III or a 1Ds III try to compare Eoscount vs uploading a raw file at Jeffrey's Exif Viewer?
I uploaded a 1D III raw file and the shutter count was exactly the same as the file number was, so I don´t think it shows correct. The 1Ds III raw file shutter count showed less than the file number. Also strange.
01-05-2016 12:50 PM
Peter where are you seeing this? It shows 0 on my 1Ds Mk III
01-05-2016 01:07 PM - edited 01-05-2016 01:08 PM
Upload a sample at Jeffrey's Exif Viewer and check down there.
I found raw files from http://www.rawsamples.ch/index.php/en/canon and uploaded them at the Exif Viewer.
01-05-2016 01:08 PM - edited 12-25-2016 09:32 AM
But what number am I comparing it to?
01-05-2016 01:12 PM
You wrote on the first page "http://eoscount.com/ will work on the 1Ds Mk III."
So if you get the shutter count out from there from your camera and compare it with the Exif Viewer it would be interesting to see if it is same or not.
01-05-2016 01:15 PM
OK. I remember that but you said, "Found today out that 1D III and 1Ds III have a shutter count tag in the image file"
I don't think this is true?
01-05-2016 01:31 PM - edited 01-05-2016 01:32 PM
I also think it isn´t correct, but the Exif viewer shows the shutter count tags for EOS 1D, 1DII, 1DII N, 1Ds, 1DsII and 1Ds III. No other camera from Canon. I heard Canon 1D II N was the last camera from Canon with a shutter count in the image file, but the same shutter count tag shows up in the viewer with 1D III and 1Ds III.
01-05-2016 01:34 PM
I u/l a photo (all 20mb) to the web site but I don't see a image number. Am I not looking at it correctly?
PS does not display an image number as I displayed above.
01-05-2016 01:35 PM - edited 01-05-2016 01:43 PM
Ctrl+F and search for count. Pretty far down.
I used this raw file http://www.rawsamples.ch/raws/canon/1dsm3/RAW_CANON_1DSM3.CR2 with firmware 2.1.2.
01-05-2016 01:43 PM
OK yes it is pretty far down. It says my 1Ds Mk III has a shtter count of 342. That is grossly inncorrect.
