07-19-2021 11:46 PM - edited 07-19-2021 11:48 PM
Have a 1DX Mark III. Absolutely in love with it. Spent Friday & Saturday evenings at the local motocross track. Needless to say gear is filthy. Need to take the bag the camera/lens is in out to the garage and use the shop vac to get all the silt off of it before opening the bag and cleaning the camera/lens. Prior to mounting the lens I did a test shot on a white piece of paper to verify the sensor was clean...it was. Started culling the images and saw a repetitive mark.....
Have seen plenty of boogers in my short time of photography but none that look like what I circled. Is that an oil smudge on the rear element of the lens? The lens I used was a 300 f/2.8 L. Last time I used the lens I had swapped the Circular Polarizer into it. It is very possible that I may have put a grubby finger or three on the clear one while swapping it into the lens.
07-20-2021 08:09 AM
In my experience it is more likely something on the sensor than a fingerprint on the front of the lens.
I'm curious why the image looks like it does.
07-21-2021 09:37 PM
Looks like a dust bunny AKA sensor dust
07-22-2021 09:42 AM
"I'm curious why the image looks like it does."
Color negative of a motorcycle rider with a pole going through him!
07-22-2021 12:28 PM
07-22-2021 12:45 PM
The vertical bar appears to a pole that is BEHIND the rider.
07-23-2021 10:39 AM
"How does one get a color negative from a 1D X Mark III. I am not familiar with how to do that."
Photoshop!
It doesn't care what DSLR you have, it will make a color negative and it can remove the pole from the rider, too.
07-23-2021 11:24 AM
