04-15-2022 04:59 PM
I just got back from Fl and took out my 128 GB SanDisk from my Canon 80D. When I put it in my computer I'm getting a error message of "You need to format the disk in drive "F" before you can use it. I put it back in my camera to see if I can see the pictures and I get a message of "Card cannot be accessed/change the card or format card with camera. Before I took the SD card out I could see the pictures on my camera but now I can't. Is there a way to get my pictures of the SD card or are these lost?
Thanks
04-16-2022 05:21 AM
It sounds like a potential card failure, to me. Is this a full size SD card? The micro-SD cards are not recommended for use any brand of DSLR that I am aware of. If you do have a micro-SD card with an adapter, then you might try a different adapter and cross your fingers.
04-16-2022 06:36 AM
Oh dear. I had this problem too when I returned from Europe, with a memory card containing all my photos of Prague. One thing I did do that I was happy about was to go to a photo shop halfway through my trip and get them to put all my photos onto a flash drive that they supplied. So not all my photos were at risk.
The cards can become corrupted. I found a program online that I was able to download and rescue most (around 95% or more) of my photos from the card. Some have missing parts and some have weird lines across but I was glad not to lose the whole lot.
i think the program I used was called Recuva. You may need to check out a few. One I used would not even recognise my card. I think I paid around $5 once I tried the free trial to unlock full features, but it was a bargain, as it was a once in a lifetime trip.
04-16-2022 07:07 AM
I just had a wild thought. Did your camera gear bag go through an x-ray machine,with the memory cards still inside of the camera?
04-16-2022 07:54 AM
At least SanDisk and Angelbird SD cards are immune to x-rays (I imagine other brands may be as well). SanDisk also lists their cards as being immune to magnetic fields.
04-16-2022 12:04 PM
Glad things turned out OK. I use SanDisk or Lexar cards.
A bit off topic but it pays to know your equipment and accessories as memory cards which can be affected by magnetic fields. Thanks for the info.
Heard of a fellow who went on a photo safari in Africa when cameras had film. Shot hundreds of feet of film. Got the film developed. Blank! Didn't know to take off the lens cover!
04-16-2022 05:55 PM
The message sounds like a card error. When you first use a card, or when you want to clean it of existing images, it is important to do a format of the card IN THE CAMERA, not on a computer that may have some differences in the way some of the formatting works. If you get error messages about a card, do a low-level format of the card in the camera (it's an option) - you should not have to do that every time you format.
As mentioned avoid micro SD cards with adapters, they can be very problematic. Make sure your cards are not cheap copies of brand units - get your cards from a trustworthy source.
04-16-2022 07:38 PM
@rs-eos wrote:At least SanDisk and Angelbird SD cards are immune to x-rays (I imagine other brands may be as well). SanDisk also lists their cards as being immune to magnetic fields.
I wonder if that immunity to magnetic fields includes magnetometers, better known as a walk through metal detector.
04-17-2022 12:33 PM
It's a full size SD card.
04-17-2022 12:34 PM
Thanks for the information. I will give it a try.
