04-24-2023 04:08 PM
Is it possible that photos I deleted in camera still show up on computer import? It seems like some of the photos I see on my computer are ones that I deleted while using the camera, but I may be mistaken. Thank you!
09-27-2024 02:02 PM
Hi there,
Thank you for your reply. I suppose I misspoke when I used the word backup. I do not use cards as my long-term backup. Typically I format my two cards in my two-card slot camera and take pictures of an athletic event all day. I cull as I go and it is this card I put onto the computer to work with. This folder will go on a hard drive as well as Google Drive for storage. The second card is a "backup" to put on my computer if my first card failed that day and I need all the images. I hope that is clearer. Thank you again for your response.
02-07-2025 01:56 PM
Recently I got a Canon R1, which has two CFexpress memory card drives, so I was finally able to record simultaneous backup RAW images to Card 2. However, since both cards were now recording the same RAW images, I could not understand why the total size of the files differed on the two drives. I thought that it had something to do with me occasionally shooting stills and videos simultaneously on the R1, a capability which the R3 does not have (to do this, one must select the video position on the two-position, stills or video switch, which is located immediately to the right of the viewfinder). The way that new functionality works is it records the videos on one card and the simultaneous stills on the other. That produces different total file sizes on the two card drives.
However, I just completed a shoot with the R1 where I did not shoot any of those simultaneous stills and videos, so I expected Card 2 to have exactly the same images and total file size as Card 1, but after I transferred Card 1 I discovered that Card 2 actually had more images than Card 1. As you explained, that was because images that I had deleted from Card 1 (my playback drive) while I was on my shoot had not been deleted from Card 2 (my backup drive). I only discovered this today (on my own) because I had set my import procedure in Lightroom Classic to NOT IMPORT DUPLICATES. That way I could easily transfer only the images (videos or still, I do not remember which) that are not on Card 1, when I record both stills and videos simultaneously. Today, as a safety check before I formatted both memory cards, I prepared to import any non-duplicates from Card 2 — and I discovered that there were some! It was only then that I realized that the only non-duplicates on Card 2 were photos that I had deleted (only from Card 1, as it turns out) while on my shoot.
I also did not know, until you said so, that my ratings that I apply to photos while on my shoots were only being recorded on Card 1. So much for having a full backup of Card 1.
This was very confusing until I finally realized (today) what has been happening for years, since I began shooting with the Canon R3.
Jan
02-07-2025 02:09 PM
I also did not know, until Brian said so, that my ratings that I apply to photos while on my shoots were only being recorded on Card 1. So much for having a full backup of Card 1.
Jan
