09-26-2023
02:05 AM
08:40 AM
I have a Canon Rebel T7, a 256mb SD card (full size not micro,) and a Mac.
When I use an adapter and plug the card in it says, “this disk inserted was not readable by this computer.” If I reformat it on my Mac then my camera says that it can’t read the card and I have to format the card on my camera. If I format the card on my camera then my Mac gives the same not readable message. I’ve done so much googling I can’t find an answer!
I’ve tried two different brands of 256mb SD cards. The only card that works on both my camera and Mac is an old 4mb card I’ve had for years.
Is the card size too big? Do new SD cards require a different card reader? (My reader is years and years old. I had been using a Mark II for 14 years and it just died and I’m unable to afford to upgrade.)
It’s been a giant headache as I photograph a service every Sunday and I now have to transfer my photos onto my mom’s PC to a flash drive to get them onto my Mac to edit. She’s only visiting so once she leaves I can’t access my photos. Please help me before I pull my hair out!
09-26-2023 02:49 AM - edited 09-26-2023 02:52 AM
For your T7, I would suggest a full size SD card UHS-I, 32GB or smaller.
SanDisk, Lexar or similar. Your cards should be purchased from a reputable source. B&H photo, BestBuy, etc.
Avoid Amazon, sellers there frequently and sometimes unknowingly sell counterfeit cards.
This is a good card. About $12 😀
09-26-2023 03:46 AM
@PhotoJenic wrote:I have a Canon Rebel T7, a 256mb SD card (full size not micro,) and a Mac.
I think you mean a 256GB card. "mb" is millibits -- a thousandth of a bit, which is impossible. "MB" would be megabytes, but there are no 256MB cards on the market. This may seem nit-picky, but the size of the card really matters, so it would help if you could confirm what you really have.
When you "format" a card, what you're actually doing is creating a new, blank, filesystem on the card. So the question is, what kind of filesystem? I don't use Macs myself, but I would guess that a Mac might create some kind of Apple filesystem. If so, then it's no wonder your camera can't read it, because a camera won't support Apple filesystems.
If you format in the camera, then it will create an exFAT fileystem -- assuming that the card is actually 256GB. It may well be that your Mac can't read this, if it's an old one. Then again...
I'm not sure about this; if your reader supports SDHC, then it might work for SDXC. But from what I'm seeing online, formatting the card may be an issue. To be safe, use a reader that specifically supports SDXC.
I have to assume you mean 4GB (4 GigaBytes, not 4 millibits). In which case, this is no surprise; the camera will format it as FAT, if it's that small, and then the Mac should have no trouble reading it.
Bottom line:
There's plenty of info about these online. The "Comparison" section of the Wikipedia article has a helpful table: https://en.wikipedia.org/wiki/SD_card#Comparison
I made a video about memory cards that might help: https://moonblink.info/MudLake/tech#Cards
You might find the other videos on that page useful, too.
09-26-2023 03:51 AM
The Canon page on the T7 says it supports SDXC: https://www.usa.canon.com/shop/p/eos-rebel-t7-ef-s-18-55mm-f-3-5-5-6-is-ii?color=Black&type=New
So 256GB should be OK... right? Or am I looking at the wrong version of the camera?
Ian
09-26-2023 05:59 AM - edited 09-26-2023 06:00 AM
The xxxxD models are listed to be compatible with SDXC cards, but they are not. Speaking from personal experience and numerous posts like this one, they do not.
My T5 would lock up, give formatting errors, and other bad things. If put the same cad into my 6D, no problem. Put a SDHC card in the T5, no problem.
Insert a different SDXC card into the T5 and cycle repeats. They don’t work.
09-26-2023 06:44 AM
Oh, interesting! Then the 256GB card may be the problem.
But if true, then that's definitely a bug. The T7 claims SDXC compatibility, and a camera that new should have it in any case.
09-26-2023 06:57 AM
I can't find anyone else having this problem with the T7.
This looks like a good guide to cards for the T7:
https://havecamerawilltravel.com/canon-eos-rebel-t7-sd-card/
He doesn't mention problems with SDXC; in fact, he says "I’ve used UHS-II SD cards in my Rebel T7, and they work just fine." All the UHS-II cards I can find are SDXC.
These articles recommend a bunch of SDXC cards for the T7:
09-26-2023 08:35 AM
Page 5 of theT7 manual states the SDXC will work along with two other cards.
09-26-2023 09:09 AM
"I don't use Macs myself, but I would guess that a Mac might create some kind of Apple filesystem."
While the native Mac filesystem is HFS/APFS, they have the capability of formatting in FAT, which is what the camera requires.
09-26-2023 09:27 AM
@Tintype_18 wrote:Page 5 of theT7 manual states the SDXC will work along with two other cards.
Maybe they have corrected the SDXC compatibility issue with xxxxD bodies with the T7. I do not think they have because there have been several posts like this one in these forums.
Do 64GB SD cards work in your T7? I tried at (4) different cards and they all eventually failed, or failed to format in the camera. Formatting in a computer only led to the inevitable failure to read in the camera. They would work for a SHORT period of time and fail.
If I put the same cards in my 6D or any other midrange body, they would work flawlessly. Since you seem to be using a T7, then I strongly caution against SDXC cards. I know what the manuals say.
The problem does not appear in the xxxD bodies like a T5i, T6i, T7i, etc.
