01-26-2019 11:38 PM
Hello - I am new here and thanks for having me.
I am having problems getting good focus with my 5D Mk II and I have just noticed that there are green outlines on left of objects and red on right edges. This occurs where there are strong contrasts especially between dark and light colours.
I am using a 24-105 mm 1:4 L IS USM lens.
What could be the problem please?
Feeling devastated.
01-27-2019 06:25 AM
That sounds like chromatic aberration. It is unusual to see in an “L” lens, though.
Notice the purple and green fringing.
The shot was highly cropped. Most lens correction algorithms can remove just about all of it.
01-28-2019 04:50 AM
Hello Waddizzle,
Thanks for the sample shots. Single colour purple in those images and I can see it in a fair bit of the image (?).
My lines are green and red with green always at left and red on right of objects.
01-28-2019 05:28 PM
Hi Waddizzle - I can see the green in those images. Yes same problem I have.
01-27-2019 07:59 AM
What software are you using? We can show you where to adjust it.
01-27-2019 05:22 PM
I am using Photosop CS6.
Only see it at 100%
01-27-2019 05:30 PM
"I am using Photosop CS6."
Shoot Raw file format and use ACR to convert the file into PS. CA is easily corrected in ACR. Also do lens correction in ACR.
01-28-2019 04:39 AM
Hello ebiggs.
I always shoot in RAW and if I remember correcrtly there was no (or barely perceptible) red/green outlines in PS RAW editor.
However, once the image opens from RAW to PS, then zoomed to 100% the lines are there.
I took this image as I was having trouble getting a focussed image (f11/100). The green and red lines are clear on the metal work against the white concrete tank stand. This is a jpeg for web, but the tiff has the lines too.
I'll look into doing what you advised.
I used a borrowed camera all last semester from uni (same Canon model and lens) yet no aberrations.
Thanks for your advice.
01-28-2019 04:53 AM
Hello jrhoffman75,
Photoshops CS6. I would appreciate to learn how to remove it, thanks.
I mostly convert to black & white but the fact that the problem is there is worrying. In the bl&wh conversion, the lines will still be visible at 100% I imagine, as lines that shouldn't be there.
Thanks.
01-28-2019 07:59 AM
https://clickitupanotch.com/chromatic-aberration-photoshop/
Here's one way. Others may have additional advice, since I am not a Photoshop user.
