10-20-2024
07:33 AM
09:12 AM
Any R5M2 owner encountered a "layer" of additional/missing colour platter in your photo taken?
Initially, I encounter image preview issue where the camara states that the "current image cannot be previewed" on the camera but didn't thought much about as it was already night and I'm shooting the cuscus near the homestay. But things took a turn the next day when I'm shooting the bird of paradise. A quick preview on some of the images show symptom the night before and worst, photos with additional/missing colour platter.
As I continue to review the images, I noticed some of the images either have a tinge of colour, e.g. green, yellow, pink etc., either in in full or partial on the images.
Initially, I thought it could be due to the slower SanDisk UHS 2 SD card wasn't able to catch-up with the write speed that causes the problem. So, I removed the SD card and let the camera write to the faster Prograde CFExpress card with the sustainable write speed of 1300MB/s.
However, the issue persisted and even more ridiculous! I took the camera for a sunrise shoot one morning, instantly, the 1st shot encountered the problem describe above on the CFExpress card. Therefore, the theory of incapable card or heating is ruled out.
Would like to hear from follow R5M2 owner if you've encountered such issues.
The camera config is as followed
Firmware v1.01 // Highlight tone priority D+2 on shooting the bird, and was disabled when shooting sunrise // Elec shutter for BOP @ H+ and Mech shutter for sunrise at single // SanDisk 256GB Extreme PRO SDXC UHS-II Memory Card with R=280MB, W=150MB // ProGrade Digital 1TB CFexpress Type B Memory Card (GOLD) with R=1700MB, R=1300MB
Thanks.
10-20-2024 11:47 AM - edited 10-20-2024 01:22 PM
The masked pixels are good to use to set the right black level or to reduce row noise. Black level 0 will give you the pale colour cast. Canon normally uses something around 512 at ISO 100 and something around 2048 at higher ISO. If you don't want to use the masked pixels to set the black level you can use the information from the Makernotes. It is often correct even if there are exceptions. DPP, Lightroom and DxO read the black level from the Makernotes. Here I have changed the Makernotes from 512, I think, to 0.
Using HTP 200 means that you are using ISO 100 under exposed 1 stop. The raw file will therefore be 1 stop darker. DPP then adds a tonecurve to make it brighter.
12-09-2024 04:54 PM - edited 12-09-2024 05:16 PM
Yes, corrupted. One of three embedded JPEG files corrupted too. This one is still okey but only low resolution. Extracted with Exiftool.
The blue pixels in the raw file are in the bad area hitting 16383. It means that they clip the highlights and do that even in the masked pixels. The value there should be 512.
12-10-2024 03:43 AM
I already downloaded and updated. Didn't see anything about this issue in the list though.
Thanks a lot.
10-20-2024 08:49 AM
It seems like there could be an issue with the camera.
Let’s dial down your settings and test the camera. Set the camera to One Shot AF and Single Shot Drive mode. Does the issue still appear?
10-20-2024 08:59 AM - edited 10-20-2024 09:57 AM
Well, it does. It happened on the sunrise shot, in fact, that shot was shoot with single drive and manual focus.
10-20-2024 10:18 AM - edited 10-20-2024 10:33 AM
Your second print screen shows the full size of the raw files. That is how a raw file from Canon looks like when it is not cropped and without black level 512/2048. Why people don't know that characteristic look is because they use software that hides those steps.
10-20-2024 10:31 AM - edited 10-20-2024 10:33 AM
No, it should not. It is clearly a defect as the pic looks like a layer of misty white was applied on the centre pic, while the one on the right is alright.
10-20-2024 10:58 AM - edited 10-20-2024 11:15 AM
The masked pixels are visible on all the images there in the second screenshot.
Here from my 6D
Your D+2 is under exposed, and that is normal too.
10-20-2024 11:29 AM
Thanks Peter.
I agree with you after closer examination. But I don't understand how the mask was applied to the RAW files. I used FastStone for previewing images prior to selecting it for edit/delete, and that as you mentioned, it was mask. In fact, only file #from *049 ~ 061 have the issue. Those before and after does not have the mask applied.
Viewing the file thumbnail in Windows Explorer also show the same. When I opened it on DPP 4.18, DPP can't even load the few files that was masked.
Upgrading it to 4.19 seems to solve the issue and shows the image correctly.
DPP 4.18
FastStone
10-21-2024 12:03 AM
Thank you for the detail explanation Peter. Much appreciated, and I've also learn something thru this. ❤️
11-03-2024 04:41 AM
Hi, Somewhat like the R52Aoo49.CR3 of Jasonleecs, all my CR3 files are washed out & have a pinkish border on the left side and across the top when looking at the file on my PC It doesn't happen when viewing on the camera I have tried different branded branded cards - both Sd & CFexpress B I have used various objects to photo & different camera settings, as well as resetting the camera & uploading update - didn't change my issue I also rechecked my PC for updates as well as DPP I have used these cards on other cameras that support these cards - taken photos & absolutely no issues opening on my PC - either DPP or straight from the card All my other CR3 photos are flawless. It's only RAW from the R5ii The SD cards are also flawless with the R5ii for JPegs Again - it's only the RAW files I couldn't load raw files onto my Ipad - requires too much power. The dealer was able to replicate this on their PC The dealer has sent my camera back to Canon. Also I've been online to Canon tech support - all been good but no solution at this stage.
