04-09-2015 11:24 PM
02-25-2016 02:25 PM
My rebel t3i wouldnt turn on! Thougt it was the battery so I bought a new one. Didn't work. Read some post and thought maybe there was a loose connetcion where the battery goes or the memory card. If either one of those isn't secure it won't work. Not the case. It was my memory card, I has switched it from my Nikon to my Canon and it wouldn't work. I put the memory card into my Mac, deleted everything off of it, put the card back in and the camera works fine. Years of using cameras and I guess I am an idiot....but you don't switch memory cards back and forth unless you format them first. MY BAD.
Happy to have finally solved this problem and at no cost..except now I have a back up battery..which isn't a bad thing.
04-10-2015 10:02 AM
The second battery is internal to camera and not user replaceable. It is charged by the main battery.
Are sure that the two batteries are fully charged? A defective charger could indicate charge but not be charging.
04-12-2015 09:40 AM
Similar problem with my T2i, haven't used the camera for a while, charged the battery and menu display won't come on. When attempting to take a picture the flash will work as will the shutter, so it seems the battery is charged. Just no display.
04-14-2015 12:37 PM
The camera has two micro-switches to verify that the (a) memory card door and (b) battery compartment door are fully closed. There are some tabs on the doors which push on the respective door switches.
Check to make sure your doors have a good fit and that the tabs aren't damamged in any way are able to close completey.
If the switches are not engaged then the camera will not power up.
04-16-2015 10:32 PM
Thanks for the suggestion. That is not the problem with the T2i. I wonder if it is a faulty - old battery or bad memory card.
06-14-2016 10:34 AM
I had a similar problem with my T3i, this morning. Camera would not power up. After reading your comments about checking the bay doors, I reseeded my SD card and battery and crossed my fingers.
To my surprise, the camera came back to life. It was really scarry, to think of replacing my baby and the money required to do so.
11-10-2018 03:21 PM
Canon rebel t3i I have two batteries and worked fine 5 days ago. SD card has been used for several years. Took out battery, took out SD card. Replaced battery and camera powered on. Placed SD card back in and camera would not power on. Placed anothr SD card in and camera works.
I was able to place the first SD card in my pc and back up the 1500 or so pictures.
Cannon website says this camera is not supported any longer
04-19-2015 12:01 AM
I just saw your post. I am having the same problem with my T3i. Just started a week ago.
10-31-2015 11:41 AM
10-31-2015 12:42 PM
I finally got a new battery that worked. Took one back to Best Buy and got another one at Staples. Some of those cheap ones from China are not worth the money. Give the new one plenty of time to charge before trying to use it. Good luck.
