Rebel T5 will not turn on
AC12
Good morning.
My Rebel T5 will not turn on.  It turned on 1x then nothing.  I've purchased and fully charged 4 batteries and still nothing.  This was purchased in 2014 and has only turned on 1x.  I haven't taken any photos.  Thought I would try again after many years of storage due to frustration.
Thank you for any suggestions.
9 REPLIES 9
rs-eos
When was it last turned on (wasn't clear from your post)? Did it turn on successfuly recently? Or had you turned it on back in 2014?
Ricky
Christmas of 2014.  It turned on 1x then never again.
I became frustrated and put the camera away.  Just pulled it out from storage and would like to start playing with my 2014 Christmas gift. 🙂
kvbarkley
You need to call Canon and send it in for repair. Unfortunately, it is now out of warranty.
Waddizzle
The door to the battery compartment has a micro switch on it, which detects when the door is securely closed.  Make the door latch clicks into place when the door is closed.
Something else to try is remove any memory card in the slot.  Remove any attached lens.  Does it still not power up?
Thank you for your reply.  I removed the memory card, no lens attached .... nothing.  Worth a try anyways
@AC12 wrote:
Christmas of 2014.  It turned on 1x then never again. Probably not cost-effective to repair now.
Sounds like it may have suffered an infant mortality failure in 2014. too late now, but probably should have been returned to seller or sent for repair in 2014.
Appears it had one breath upon arrival. Agree, “I should have … “.  Thank you for pointing out the obvious. I do appreciate positivity and realism.
New/used camera purchased today. Just can’t toss that one in the trash just yet. You appear wise….. any insight how to donate a starter camera that doesn’t work?
jrhoffman75
You could try and sell on eBay for parts. Could probably get $100.
