01-13-2014 06:23 PM
I took a RAW shot of Jupiter with my EOS T3i, and background stars appear in red and blue, as well as white. However, when converted to JPG in Digital Photo Professional, the stars lose their color and all are white. Is there a way to convert to JPG without this colour loss?
Also, Photoshop CS2 will not read the .CR2 files. Is there a workaround? If not, is there another photo editor I can use?
01-13-2014 06:44 PM
You should be able to convert the CR2's to DNG's which can then be processed in CS2.
01-13-2014 07:01 PM
01-13-2014 07:03 PM
The red/blue sounds more like noise than stars. It's either noise or hot pixel which will be remove upon converting to JPG.
01-13-2014 08:35 PM
I've tried Adobe's DNG converter, but it doesn't see the .CR2 files.
01-13-2014 09:34 PM
01-13-2014 10:01 PM - edited 01-13-2014 10:09 PM
then can you put up some sample photo? If it's sharp dot, it's more like noise because at 250mm, in order to capture a star as a sharp dot, you'll need exposure time of 1.25 second or shorter. Anything longer will make your stars blurry. Also I assume your lens will not be wide (F2.8 or larger), so there is no way you can capture it as a sharp dot unless you're using tracking device of some sort.
01-13-2014 10:04 PM
If I remember correctly Tim & at least one other member here are heavily involved in astro photography so I'd be inclined to think it's noise or hot pixels etc vs colored stars.
01-14-2014 09:27 AM
I would like to know your detailed set-up.
If you have a T3i with the 55-250mm f4-5.6, I am surprised you got anything. You could be seeing some CA. That lens at full zoom (250mm) is not real good.
Also what settings in the camera did you use.
01-14-2014 09:30 AM - edited 01-14-2014 01:46 PM
"Also, Photoshop CS2 will not read the .CR2 files. Is there a workaround? If not, is there another photo editor I can use?"
Yes, update you Photoshop. What version do you have? PS is the software of choice.
Need way more info from you.
