07-01-2025
09:39 PM
09:25 AM
I recently purchased a new R7. I am trying to use a Tamron 90mm macro SP Di EF-mount lens adapted with a meike EF-RF adapter. Everything with the lens works just fine, but the IBIS is deactivated whenever using it. The lens does not have IS, and the menu option for enabling IBIS does not appear when I have this lens attached. When I use my Canon 18-55mm EFS lens on the R7 with this adapter, IBIS works and is enabled/disabled via the lens IS switch as expected. I think perhaps with the Tamron lens, the adapter is erroneously communicating to the camera that it has IS and that it is disabled. Does anyone have experience with a work-around for this problem?
07-01-2025 09:46 PM
Stick with the Canon brand adapter. 3rd Party Mount adapters cause nothing but trouble. It could also be an incompatibility with the lens.
07-01-2025 09:56 PM
deebatman316 gives sound advice, I used the Meike adapter and it also had challenges. It went back and I picked up the inexpensive Canon adapter. I can only add that you may want to check to see if you have the latest firmware for your lenses.
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
07-04-2025 01:28 PM
I purchased a canon adaptor and it did not resolve the problem. The camera is still incorrectly detecting that the lens has stabilization and is deactivated. Bummer.
07-04-2025 01:34 PM
If it were working correctly both IBIS & lens IS work in tandem. These 2 systems cannot work independently of each other.
07-04-2025 01:34 PM
Hey crispy, do you have a local shop that can check and update the firmware. That would be my next move.
Personal Gallery
07-04-2025 02:17 PM
The lens does not have stabilization. The camera is incorrectly detecting that it does, and also that it is deactivated. So IBIS is not active and I cannot enable it. Even with the canon EF-EOS RF adapter.
07-04-2025 02:19 PM
This lens predates Tamron's tap-in system and Tamron has not created any firmware updates for it.
07-04-2025 02:21 PM
In my last post this was in regards to a lens with IS. Lenses without IS rely solely on IBIS if enabled. You likely have come across an incompatibility with the lens. You can reach out to Tamron about this and see if the firmware can be updated.
07-04-2025 02:33 PM
"This lens predates Tamron's tap-in system"
deebatman316 probably nailed it, because of the age of the lens and the inability to update the firmware it's incompatible with the R7 and most likely any of the R series bodies. I may be incorrect but I believe that the Tamron 90mm macro SP Di EF was released in 1997, it's a bit dated.
Personal Gallery
