R7 Firmware v1.6.0 IBIS bug.
Pippers
I have found a bug in the R7 firmware v1.2.0 through 1.6.0
With manual lenses that have no communication, the IBIS Image Stabilization is not working as expected. It is not using the correct "Focal Length" value that is inputed. IBIS is enabled, but it is ignoring the value that is set when turning the camera on. You can temporally fix this turning IS OFF, and then focusing with half press, then turning IS back ON. The R7 IBIS then behaves normally with the correct "Focal Length" value. When the camera is turned off, or goes to sleep it breaks again. This behaviour is best witnessed by using the 10x zoom through the viewfinder. You will see the effect of IBIS with IS ON as-is with incorrect value interpreted (Slight shake correction), with IS OFF (No shake correction), and finally with IS ON with correct value interpreted(Fantastic shake correction).
58 REPLIES 58
lfz
Does anybody still have this problem with firmware 1.5.0 and 1.6.0? I reported this but Canon staff said this has been solved in 1.5.0, and my camera is an outlier. I think they are talking bull**bleep** but still want to verify in the community.
Herman54
Problem with ibis using third party lenses is occurring in firmware 1.5. in my R7.
After update to 1.6 problem is still there! Workaround  to make ibis to work after having taken a picture is
  1. Restart R7 - or-
  2. Set ibis to off and on again
My question: Has canon acknowledged the problem? And have they mentioned somewhere that with such or such update it should have been solved?
Kind regards
Herman
If I put in the settings of the camera that I’m using a 8mm lens ibis should work accordingly. And it does when turning OFF and ON the camera. So why does all of all of a sudden ibis fail after having taken a picture? … Then after turning ibis off and on again it is working fine. But only for 1 picture. How can canon find a solution if they don’t acknowledge the problem. Why don’t they take an R7 and put on whatever third party lens with no electronic connections and they will see for themselves.
As an answer to your second question: the problem occurs in every setting: M, Av, Tv…and also C1, C2 after registering.
Pippers
Problem is still there on the R7 even with the latest firmware 1.6.0.
IBIS works for the first shot. Once taken, IBIS is broken. Everything is shaky. If I go into IS Mode and turn it OFF and hit the focus/aper lock button, then set IS Mode to ON IBIS works again SOMEWHAT. It goes to smooth to jerky at random. Like it's confused that IBIS is on or not.
I really wish they'd fix IBIS. It's why this dang camera is so expensive. It's a $500 premium that hasn't worked since it was released.
Herman54
Hi! I have some good news!
I did some more tests today and these are the results for my R7 and falcon 8mm fisheye lens after updating to firmware 1.6.
When you freshly start the R7 up,the first foto ibis is ok. The second foto ibis is not working. But after setting ibis off and back on, from then on, every foto ibis is ok. The same with waking the camera up after sleep mode. So in my experience after setting ibis off and on ibis is working for every foto you take until you shut R7 down or until it goes not sleep mode
Ronomy
I discovered the same problem with my R7.  Using an all manual lens.  TTartisans 7.5mm for RF mount.  There is no communications this I set focal length in the camera.  What i found is the same as you.  Turn on camera and IBIS is working.  Take one picture and IBIS is jumping all over the place.  What i also doscovered is if I change the focal length in the IS setting in the menus and save again.  IBIS will work fine while the camera is on and after multiple images.  But as soon as you turn it off and back on.  The first picture IBIS works and every picture after the first it does not.  If i want every picture to have IBIS working I have to reset and save the focal length in the IS menu.  Then dont turn off the camera or you have to reset focal length again.  Or you can just turn off IBIS and use higher shutter speeds.  Thats fine in good light...
I dont think its disabled after you take your first picture.  IBIS is shifting the sensor around too much and cant stabilize.  If you turn it off its no way near as jumpy.  I already posted you can reset the focal length in the IS ment and save.  After that IBIS works every shot until you turn off the camera.  Turn it back on and IBIS works for one picture then its jumping all over the place.
Spot on response!  Exactly... Canon listen up!
“ Turn on camera and IBIS is working.  Take one picture and IBIS is jumping all over the place.  What i also doscovered is if I change the focal length in the IS setting in the menus and save again.  IBIS will work fine while the camera is on and after multiple images.  But as soon as you turn it off and back on.  The first picture IBIS works and every picture after the first it does not. “
Why do you feel the way that the IBIS is reset following a power cycle is a bug?
The camera can make one of two assumptions when you power it back up and it doesn’t find a lens on its mount..  The same lens is still mounted, or the lens has been replaced with a different one.
Which choice should it make?
Friends and Family
