05-03-2021 12:01 PM
Is anyone else having issues with their R6 and brightness? I am having two main issues: when I focus, as I push the button, everything lights up to what the shot really should look like, but only for a split second, and then it goes back to a much darker shot and that's what stays when I hit the trigger.
Also, when I'm out in a sunny day, the entire back of the screen and the viewfinder goes completely white. I can't see anything unless I crank my F stop up super high, as well as my shutter speed. I mean to REALLY high numbers to make things as dark as possible to even be able to SEE the scene. Doesn't matter which lens I have on.
I've been having these issues since I bought it in Fall. I've tried to adjust settings, factory resets, firmware updates, etc, but something is just really "off" with it (and not just outdoors). I barely touch it now because I'm so frustrated with it and don't enjoy it at all and regret buying it.
And just for the record, I can take the same shot, settings, etc just fine with my 5DMIV.
05-03-2021 02:13 PM
It sounds like you have your ISO cranked up very high. For the scenario where you are seeing the all white screen, what are the current camera settings?
05-03-2021 03:41 PM
No, it wasn't. I should've clarified that in my post. Sorry. The whole thing is just puzzling.
05-03-2021 04:04 PM
Are you using flash at all? Perhaps the camera is switching the camera to the sync speed?
We'll need more information. What settings/setup do you have?
05-03-2021 04:21 PM
No, no flash. I really don't know how else to explain it or the settings because no matter what I did, until I cranked everything up to make it dark, you couldn't see anything but this crazy blinding white screen/scene. I'll need to video it when we get a bright day again - should've did that yesterday. I was just hoping someone would have also experienced it and had a fix/suggestion.
05-03-2021 06:28 PM
You need to provide a little more information. There are too many unknowns beginning with what lens you're using.
I recommend resetting the camera back to factory defaults, taking a few test shots in P mode.
05-03-2021 06:32 PM
Thanks. I'll just contact the support team and see if they can help. I really think it's a defect issue. It happens no matter what lens is on it. (Any of my RF, EF with adapter, etc.) And I have reset to factory settings already but it didn't help it. But thank you. I appreciate the replies.
05-03-2021 07:52 PM
Do you have a camera store or a camera club nearby? They might be able to help hands on.
07-10-2022 03:11 PM
Okay I’m literally ha I g this exact same issue! Shooting in perfect day light, and my ISO is at 100, I have a completely white screen! But I can see all the settings! Did you ever fix it?
07-17-2022 05:17 PM
I just bought my camera a few days ago. I'm having the exact same issue. It makes no sense at all.
