07-19-2020 08:12 AM
07-19-2020 08:53 AM
Adding shutter angle would make it necessary to restrict the range of available shutter speeds.
07-19-2020 09:06 AM
07-19-2020 09:08 AM
@JJacksonFilms wrote:
You could just make a separate mode where the shutter range is restricted to access the shutter angle. That way if you don’t want to use shutter angle, then the normal mode is available.
Canon's line of Cinema EOS cameras have shutter angle, and a lot of other features.
07-19-2020 10:54 AM
07-19-2020 11:01 AM
That still isn’t a good reason for it not to be included in the R5. Panasonic have it in their S1H and GH series of cameras.
I suggest that you contact Canon directly with your suggestion. This is merely a user forum, not product support.
08-07-2020 09:35 AM - edited 08-08-2020 02:11 AM
@Waddizzle wrote:
@ WalgreensListens wrote:
That still isn’t a good reason for it not to be included in the R5. Panasonic have it in their S1H and GH series of cameras.I suggest that you contact Canon directly with your suggestion. This is merely a user forum, not product support.
