09-20-2021 01:04 AM
09-22-2021 06:21 AM
Have you looked at LumaFusion for the iPad?
09-22-2021 01:09 PM
Are you sure you even need to deliver 8K to iPads? That's rather pointless since the max possible resolution of an iPad (12.9 inch) is 2732 x 2048 which is less than 4K.
8K I believe is currently just an acquisition format and really not yet meant for delivery. Especially not to mobile devices.
09-20-2021 07:13 AM
Might not be possible.
09-20-2021 11:45 AM
Thanks, John for sharing that link. In that case, I have to wait until Apple provides support for them on AppleTV and iOS platform.
09-20-2021 11:49 AM
What codec are you using though for the footage? On iPadOS/iOS, while there is iMovie and the Photos app, that's not going to work with every possible codec.
You typically need a non-linear editor such as Final Cut, Adobe Premiere, Davinci Resolve to work with those codes and then output to something that can work with Apple Devices.
For all my EOS C70 footage, I capture XF-AVC 10-bit 4:2:2 CLog2. Either in All-I or Long-GOP. Then, I import into Final Cut, edit, the export as-needed for web, Apple devices, etc.
09-21-2021 03:39 PM
Thanks, Ricky.
I am not sure about the codec in the 4K 120fps recording of R5. I think it is a10-bit 4:2:2 ALL-I (HEVC, H.265).
I explored Premier Rush and it is useless for this. I have now downloaded the 90 day trial version of FInal Cut Pro to experiment with it. I need to learn the basics of this tool now. It seems to load and play both the 8K 30fps and the 4K 120fps videos on my iMac.
09-21-2021 03:54 PM
09-21-2021 06:04 PM
Thanks, John. I downloaded the free version of Resolve. Unfortunately, it can output to 1080p max. 4K and above is available in the paid version.
Is there a format of 4K 120fps that Apple devices would support? If yes, then transcoding to that could be the solution.
09-22-2021 06:21 AM
09-22-2021 12:03 PM
Thanks for the pointer, John.
Lumafusion is far cheaper than FCP (10% of FCP, no trial versions) and the interface is simple and superfast. It processed my 4K 120fps clips and was able to output 4K videos that my iPad, iPhone and Apple TV 4K could play. However, it has a severe shortfall when dealing with 8K. It can play it, but it outputs it to max 4K.
I played with the FCP and it was able to do both 4K 120fps and 8K and output it while retaining the same resolution and the output files were reasonable compact and I could play them on iPad, iPhone and Apple TV 4K.
It will be nice to get an app on iPad that output 8K. Glad I started this thread as I am learning a lot.
09-22-2021 01:09 PM
