07-25-2020 09:31 PM - edited 07-25-2020 10:31 PM
Canon has released a spec list for which classes of cards it recommends. But specific brands of CFexpress cards range vastly in speed. Every where from 800 - 1600 MB/s Anyone see a recommend read/write speed. The Canon 1dxmkii & iii even came with a Sandisk card with preorder, so you at least had an idea. Has anyone seen an official list of approved card speeds?
07-26-2020 11:10 AM
I'm sorry you seem to be confused. We are referring to the Canon R5 and the 1dx mk iii. Both use CFexpress.
I referenced the 1dx mark ii at the beginning because I remember a document just like the one John posted. It was very simular in nature.
But all this talking still does not get to the point of the original post.
I'm looking for the samething John posted but the R5 version.
07-26-2020 11:40 AM
@ImageAndFilm wrote:I'm sorry you seem to be confused. We are referring to the Canon R5 and the 1dx mk iii. Both use CFexpress.
I am not confused. I answered your original post. The answer is still, "No, they do not." You retconned the original post.
07-26-2020 01:03 PM
Wad. Have a nice day.
07-26-2020 01:46 PM
07-26-2020 02:10 PM
07-28-2020 04:51 PM
08-05-2020 07:10 PM
@Wadsizzle
I really do not appreciate being called a Troll. Your comments were unwarranted and disrespectful.
Here is the screenshot. Maybe instead of tearing others down you should rethink the way you interact with others. Be kind.
08-05-2020 07:58 PM
Your first post is just below. No one replied to it, and for good reason. It was very argumentative.
This thread is your second post. You changed the original content. That is really bad web etiquette.
https://community.usa.canon.com/t5/EOS/R5-FALSE-listed-specs-Announcement-FullHD-120fps/m-p/314339
08-05-2020 08:25 PM
08-07-2020 11:02 AM
Beat the recording limits and overheating in canon R5!
Canon is definitely hiding information, they are intentionally holding back their camera with software.
New discoveries have found that the real problem for the camera are the cfexpress/sd cards in the camera! These cards initiate the temperature timer in the camera Giving you the limited said recording time by canon. But recording externally with out the cards in the camera you actually trick the camera from overheating limit issue that become the biggest problem with virtually every R5 user.
The cfexpress card slot and sd card slot makes the camera heatup more so in the card slots more than the whole camera. Yes we know that a lot of data is being pushed but that still doesn't explain why this limits the camera recovery time and record time. The slots are either faulty and canon needs to do a recall or canon needs to optimize the software to work with the new media and remove the limits and bad recovery time. Period
The cat is out the bag! I tested this with my own R5 there is definitely something going on here !
youtube NOLIFE
Pt 1
https://www.youtube.com/watch?v=PnG00Fhu5pI
Pt 2
