05-24-2023 05:43 PM - edited 05-24-2023 05:45 PM
Long time listener, first time caller....
Having some wacky issue with my EOS R5 trying to update the firmware from 1.7.0 -> 1.8.1. When I attempt to run the firmware upgrade utility, the camera reboots. (See video of said shenanigans here: https://youtu.be/V9wjgpU7VqM)
Here's important information:
- Problem occurs both if firmware is present on the SD card id executed via the camera menu and if the firmware update is started via the EOS Utility app directly connected to my laptop via USB.
- Camera has two full batteries
- Camera is stable and does not reboot *EVER*. It only exhibits this behavior during the firmware update program.
- I have performed a full camera reset and re-attempted the upgrade and the same issues occur.
- The file I am using is EOSR5181.FIR
Looking for guidance from the community.
Thanks,
Sean - DESTINATIONS UNKNOWN
https://destinationsunknown.com
05-24-2023 10:49 PM
Adding to Ricky's suggestion.
Remove grip from the camera, just use a single battery. If you have any accessories installed, remove those as well. Lens too, its not needed.
Remove both memory cards. Use an SD card for the upgrade. Format the card in camera. Use a card reader and copy the .FIR file to the root of the SD card. Insert that one card and perform the FW upgrade again.
Let us know the results.
05-24-2023 09:48 PM
I see you have a battery grip. Wondering if there something about that setup that is causing issues with the update. Thus, try disconnecting the battery grip and seeing if the firmware can then be updated.
05-24-2023 10:49 PM
05-26-2023 11:49 AM
Hey guys - Thanks for responding so quickly. I took your advice and broke down the rig with just one battery and no lens and the upgrade was successful!
Thanks everyone!
Sean
