02-16-2025
06:33 PM
06:35 PM
Mike
All,
I have an R10. Last night I took some pictures. I wanted to view what I was shooting through the LCD instead of the viewfinder. When I turned the LCD around so that I could see what I was shooting I could only see the Screen Information Settings. I use Screen Information Settings number 5 (analog settings). I had to use the viewfinder. What do I need to do so that I can use the LCD to view what I am shooting? Thank you in advance.
02-16-2025 08:34 PM
Cantrell,
If you go to your manual, and in the Table of Contents under Setup, look in the 15th subheading or subchapter under Screen and Viewfinder display. It will explain how you can setup your camera to use the Viewfinder, or the screen or both.
Steve Thomas
02-16-2025 07:19 PM
Have you tried pressing the info button to see if live view view works. By default the camera shows the metering settings.
02-16-2025 08:34 PM
Cantrell,
Steve Thomas
02-16-2025 10:47 PM
Steve and Demetrius,
Thank you for your responses.
02-17-2025 04:21 AM
If those replies have helped you, you could mark one or both of them as solutions. That way, anyone else researching the same question will find the answer more easily.
02-17-2025 07:13 PM
AtticusLake,
Thank you for your response.
