10-02-2023 04:29 PM
Hey folks,
I use an EOS 5 Mark3 to stream via HMDI (with Blackmagic Ultra studio recorder card) to a Macbook Air M1.
But the stream is always reconnized as a poor signal (NTSC 720x486). I tried to choosed PAL and try 50i or 24p cadency, but I still can't get a great 1920x1080 stream.
Please could give me any help? I spent my full day on this issue :-)!!!
10-02-2023 06:53 PM
Have you tried different HDMI cables?
10-02-2023 07:08 PM
Yes, 3 different Hdmi cables 😞
10-02-2023 07:37 PM
If you have the EOS 5D Mark III, then that camera body does not support “Clean HDMI” output. People come up with clever work arounds, but I do not know what they are.
As for the resolution of your HDMI output from the camera, is your camera in Movie Mode? If not, then you could be seeing the output that is normally directed to the rear LCD screen for still shooting.
10-03-2023 04:23 PM
Thanks a lot Waddizle,
But it seems EOS 5D Mark III support “Clean HDMI” output, there is a Mirroring/ Not mirroring mode.
Whatever, the first problem is the capture of this poor signal. Actually, you're right, it seems like the stream is like the output that is normally directed to the rear LCD screen. But I'm in Movie Mode. But the LCD always shut down when the Canon is connected via HDMI. I can't get the signal on the LCD with it's connected to HDMI, this is not normal? So this could validate your intuition?
